sohc vtec or dohc vtec which one easier
Old May 14, 2003 | 07:41 PM
shadowstylz's Avatar
Default sohc vtec or dohc vtec which one easier
would it be easier for me to put a ex motor in my 90dxhb or a b16
Old May 14, 2003 | 08:00 PM
JCracer723's Avatar
Default Re: sohc vtec or dohc vtec which one easier (shadowstylz)
same. just matter or how much money u wanna spend
Old May 14, 2003 | 08:33 PM
SC0TT's Avatar
Default Re: sohc vtec or dohc vtec which one easier (JCracer723)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCracer723 &raquo;</TD></TR><TR><TD CLASS="quote">same. just matter or how much money u wanna spend </TD></TR></TABLE>
Yup. A lot more parts are needed for a b-series swap.
Old May 14, 2003 | 08:34 PM
dingusjt's Avatar
Default Re: sohc vtec or dohc vtec which one easier (cr-tegra)
ex would be a lot cheaper...talking about around $1500 for b16 swap and $400 for d16z6 swap.
Old May 14, 2003 | 09:39 PM
d-wreck's Avatar
Default Re: sohc vtec or dohc vtec which one easier (dingusjt)
the z6 would be much easier to do just run a few wires put in a different ecu, unless you want to run your nonvtec ecu
but performance wise, a z6 ef is going to take some work to get it as fast as an ef with a stock b16a.
but hey id you plan on beating the **** out of it and racing it all the time at your raceway doing track days, autox and etc, id get a fresh stock motor, or do decent z6 motor, since the cost will be much cheaper and the availability of parts for the z6 is just as far as the junkyard
derek
Old May 14, 2003 | 09:57 PM
SC0TT's Avatar
Default Re: sohc vtec or dohc vtec which one easier (d-wreck)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d-wreck &raquo;</TD></TR><TR><TD CLASS="quote">the z6 would be much easier to do just run a few wires put in a different ecu, unless you want to run your nonvtec ecu </TD></TR></TABLE>
Using a ex/si ecu (obd-1) requires a bit more effort than plugging a few wires. If you use a Si ecu (obd-0), you will have to come up with a vtec activator. Wiring the z6 and b16 engine is very similar.
It all depends on your cash flow. Obviously the b16 will be quicker in stock form.
dem0nk1d
10
Dec 9, 2007 08:18 PM
808k20a2
Sep 19, 2007 06:15 AM
the king.
Jan 28, 2007 01:55 PM
wptatl
Feb 4, 2006 09:04 PM
CRXSiA1
48
Nov 8, 2004 11:46 AM
