Custom Turbo Kit
Old May 14, 2003 | 07:27 PM
B16aef9's Avatar
Default Custom Turbo Kit
I have a Brand New!! CUSTOM Drag Turbo Kit
Here is a detailed list of everything you will be getting.
t4e 54 trim stage 3
t4e 60 trim I also have this turbo if you would like to change it for the one above.
DRAG 4 into 1 Cast Iron Turbo Exhaust Manifold
TIAL Wastegate Boost adjustable up to 20psi with boost controller.
Large Spearco front mount intercooler with polished cast aluminum end tanks (the largest intercooler you can fit on Honda without cutting)
Blitz DD blow off valve
DRAG Mandrel-Bent Chrome-Plated Piping 2 1/4 IN/ 2 1/2 OUT CHARGE PIPE
DRAG 2.5" Exhaust Down Pipe
DRAG Blue Silicone Couplers and Clamps
High flow secondary inline fuel pump -Vortech 12:1 calibrated boost dependent fuel pressure regulator
High flow DRAG intake system with funnel ram filter
Wastegate dump tube (forces the exhaust gases down and away from your air vents)
Map Sensor Bypass Valves
Heavy duty black vacuum line
Steel braided Goodrich dash-8 oil feed line
Heavy duty insulated oil return line
All necessary hoses, brass fittings, bolts, clamps and gaskets
NGK spark plugs
Please "EMAIL" me with any further questions you might have or if you would like to purchase the kit
ProjectSpeed@aol.com
Old May 14, 2003 | 07:35 PM
B16aef9's Avatar
Default Re: Custom Turbo Kit (B16aef9)
I have 1/4 mile times that others got on the same custom kit and pictures if interested in either please give me a email
PROJECTSPEED@AOL.COM
Old May 15, 2003 | 05:49 AM
B16aef9's Avatar
<bump>
milton
Jan 11, 2006 05:28 PM
milton
Jan 6, 2006 09:53 PM
7mile
Dec 30, 2005 07:32 PM
7mile
Nov 25, 2005 01:29 PM
milton
Oct 19, 2005 10:07 AM
