3 Quarts good enough for a GSR?
Old May 14, 2003 | 05:40 PM
Mark's Avatar
*Bounty Hunter*
Default 3 Quarts good enough for a GSR?
I changed in 3 quarts of Mobil 1 10w30 today...3 quarts seemed to do it...or am I 1 qt off?
Old May 14, 2003 | 05:42 PM
Al Bundy's Avatar
Default Re: 3 Quarts good enough for a GSR? (94BlackCivicEX)
It should be around 4 1/2 quarts.
Old May 14, 2003 | 05:44 PM
B U N M A N G O's Avatar
depends how long you drained your oil for and if you changed your filter... should be around 4qt though.
p1ccoloz's Avatar
Default Re: 3 Quarts good enough for a GSR? (Al Bundy)
yea thats what i was gonna say 4-4.5
Old May 14, 2003 | 05:45 PM
Mark's Avatar
*Bounty Hunter*
Default Re: 3 Quarts good enough for a GSR? (p1ccoloz)
hmmm
VTEC kicked in methinks...I drained it completely...using older filter cuz I couldnt remove it *yet* ... Ill add some more after I wake up lol
Old May 14, 2003 | 05:53 PM
KingJeff's Avatar
would 4 be sufficient?
Old May 14, 2003 | 05:54 PM
jabroni95gsr's Avatar
Default Re: 3 Quarts good enough for a GSR? (Jeff K.)
the manual says 4.2 for a GSR.
Old May 14, 2003 | 05:58 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: 3 Quarts good enough for a GSR? (jabroni95gsr)
I drain my oil usually for 15-20 minutes, change the filter, put the car back on the ground, then put in the new oil. 4 even quarts always brings the level to just a hair above the top hole on the dipstick, so therefore I only use 4 quarts exactly.
Old May 14, 2003 | 06:22 PM
95GS-R's Avatar
Default Re: 3 Quarts good enough for a GSR? (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">I drain my oil usually for 15-20 minutes, change the filter, put the car back on the ground, then put in the new oil. 4 even quarts always brings the level to just a hair above the top hole on the dipstick, so therefore I only use 4 quarts exactly.</TD></TR></TABLE>
Yep, same here.
Old May 14, 2003 | 06:25 PM
WiggiE's Avatar
New User
Default Re: 3 Quarts good enough for a GSR? (95GS-R)
I use 4 quarts as well. Even with discrepencies in draining it, 3 will not be sufficient. Either way check the dipstick as that will be a sure indicator.
Old May 14, 2003 | 09:35 PM
wall of tvs's Avatar
That is my techinque, BUT....
One thing many ppl forget to do is to pour some oil into the new filter before installing it. I usually fill it up, let it "soak in," and fill it up again before putting it on. That way, the chances of starting the engine "dry" is diminished. Plus, it is a good way to put in that extra 0.2 qts of oil.
Old May 15, 2003 | 12:04 AM
AllmotorJunkie's Avatar
4 to 4.5 has been the normal for my GSR.
Old May 15, 2003 | 12:08 AM
NA gs-R 05 C
Guest
Posts: n/a
Default Re: 3 Quarts good enough for a GSR? (AllmotorJunkie)
i use 4 qts and new filter every 3k miles. so 4 - 4.5 is good.
Old May 15, 2003 | 04:13 AM
Community Builder
Default Re: 3 Quarts good enough for a GSR? (wall of tvs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wall of tvs &raquo;</TD></TR><TR><TD CLASS="quote">
One thing many ppl forget to do is to pour some oil into the new filter before installing it. I usually fill it up, let it "soak in," and fill it up again before putting it on. That way, the chances of starting the engine "dry" is diminished. Plus, it is a good way to put in that extra 0.2 qts of oil.</TD></TR></TABLE>
In the past 5 years of changing my own oil I have never put any oil in the filter and I have never had any problems. Even after running my engine (so oil circulates through the filter), if I come back and check the oil the next day, the level will still be up to the top hole or a hair above.
Old May 15, 2003 | 07:41 AM
WiggiE's Avatar
New User
Putting oil in the filter is a un-known. There isn't any facts to back up either side. But IMO, it takes 2 seconds to dump a little oil in there. Call that cheap insurance. If nothing else you just added 2 seconds to your oil change with no harm being done otherwise.
Old May 15, 2003 | 09:29 AM
Aaron M's Avatar
Default Re: 3 Quarts good enough for a GSR? (WiggiE)
4.5 puts me at the top mark
You guys need to blow out your old oil(take valve cover breather hose and blow in it)
Old May 15, 2003 | 10:20 AM
btl fed's Avatar
Default Re: 3 Quarts good enough for a GSR? (SilverB18C1)
Honda/Acura says to use 5w30....and it should be 4 quarts, plus fill the oil filter about half way
Old May 15, 2003 | 10:30 AM
Default Re: 3 Quarts good enough for a GSR? (btl fed)
5w 30 is a little light...i know they recccommmend ( ) it, but i use 10 30, my engine uses the 5 30 like water.
Old May 15, 2003 | 10:38 AM
Seedc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jabroni95gsr &raquo;</TD></TR><TR><TD CLASS="quote">5w 30 is a little light...i know they recccommmend ( ) it, but i use 10 30, my engine uses the 5 30 like water. </TD></TR></TABLE>
same here. ive been using 10w 30 mobil one for the past few months.. I noticed a little decrease in my mpg. oh well
Old May 15, 2003 | 12:10 PM
slowman's Avatar
I took way too long
Default Re: 3 Quarts good enough for a GSR? (kendogg)
i put 4 quarts in my d16a6.
Old May 15, 2003 | 01:09 PM
VTECorona's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">4.5 puts me at the top mark
You guys need to blow out your old oil(take valve cover breather hose and blow in it)</TD></TR></TABLE>
Does alot more oil come out after doing that or are you B\Sing?
Old May 15, 2003 | 01:12 PM
Boost Ambassador's Avatar
4 quarts in my ls
Old May 15, 2003 | 01:15 PM
mr.beeks's Avatar
Default Re: 3 Quarts good enough for a GSR? (97RedTegGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97RedTegGSR &raquo;</TD></TR><TR><TD CLASS="quote">
Does alot more oil come out after doing that or are you B\Sing? </TD></TR></TABLE>
nope he just likes to blow!!!
Old May 15, 2003 | 03:22 PM
Aaron M's Avatar
its not BS....I get a good .5 quarts out of the system by doing this. and not just any .5 quarts, its the nasty chunky kind
Old May 15, 2003 | 03:36 PM
Russ713's Avatar
dAng!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94BlackCivicEX &raquo;</TD></TR><TR><TD CLASS="quote">I changed in 3 quarts of Mobil 1 10w30 today...3 quarts seemed to do it...or am I 1 qt off?</TD></TR></TABLE>
lets see. Why don't you try this idea? USE THE DIP STICK .
