Anyone know how much cfm is needed to cool an AC condensor on a B16?
We'll a while ago I swapped out the stock AC condensor fan and replaced it with a Rapid Cool Electric Fan by Hayden. It's basically a slim fan similar to Spal and all those others although you can buy this one from Orielly and Autozone. While driving during the day with the AC on in Houston, which is very hot, I started to hear a noise and noticed that my AC compressor is spitting out freon from the valve on the compressor. Come to find out, it only does that when there is too much pressure in the lines which is a result from the fan not cooling the AC condensor properely. I only have this problem during the day when it is hot outside. What I need to know is how much CFM is needed to properly keep the AC condensor cooled? The 10" fan I have now pushes out 650 cubic feet per minute free airflow, and 500 cubic feet per minute airflow across a typical radiator. I know it's not on a radiator, but I am just using what it say's on the box as reference.
I have the option of going to a 12" fan of the same brand that pushes 850 cfm free airflow, and 675 cfm across a typical radiator.
Any help would be great, t!hank's
Yeah , but I wanna see if anyone think's if the numbers on the 12" will be good enough. If not I might as well put the stock fan back on!
94_civicEx
Honda Civic (2006 - 2015)
Jun 13, 2014 12:28 AM
turbo Si
May 15, 2003 08:04 PM
