ctr pistons and itr rods in a GSR motor? i messed up this is what i meant
Old May 14, 2003 | 04:15 PM
JoRoGSR's Avatar
Default ctr pistons and itr rods in a GSR motor? i messed up this is what i meant
i messed up i meant to say pistons instead of cams
Old May 14, 2003 | 04:20 PM
WiggiE's Avatar
New User
Default Re: ctr pistons and itr rods in a GSR motor? i messed up this is what i meant (JoRoGSR)
Calculate away.
http://www.c-speedracing.com/h...c.php
Old May 14, 2003 | 06:55 PM
JoRoGSR's Avatar
i need to know will they work right in the gsr motor if not i am seelin a set of ctr pistons
Old May 14, 2003 | 07:01 PM
WiggiE's Avatar
New User
Default Re: (JoRoGSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JoRoGSR &raquo;</TD></TR><TR><TD CLASS="quote">i need to know will they work right in the gsr motor if not i am seelin a set of ctr pistons</TD></TR></TABLE>
I need to know will you get your grammar now or later?
You never asked if they would work right in this post. You asked if they would work right in the other post.
Here's what you should do from now on:
1. Collect your thoughts
2. Make an outline
3. Type it out
4. Check for grammar and spelling errors. (Hint - The little button with ABC and a checkmark below it is a spell checker.)
5. Post your question
6. Reread and revise
Now, on to your question. The CTR pistons and ITR rods will work in a GSR motor. In fact the CTR pistons will bump up your compression to around 12:1 which is a good CR for 93 octane gas. But it's not too aggressive and unreliable to run on the street.
Modified by WiggiE at 11:50 PM 5/14/2003
Old May 14, 2003 | 07:07 PM
TRuST's Avatar
Default Re: (WiggiE)
I thought was like 12:1 according to c-speed CR calculator.
oops 12:1
Old May 14, 2003 | 07:51 PM
WiggiE's Avatar
New User
Default Re: (TRuST)
You are correct. I edited my response for correction.
Old May 15, 2003 | 07:10 PM
JoRoGSR's Avatar
12:1 is still alot but can i do a thicker gasket to lower a little
Old May 15, 2003 | 07:33 PM
JoRoGSR's Avatar
come on guys. i would like to hear from alot more people about this.
Wiggie where you from in cincy?
Old May 15, 2003 | 07:42 PM
TRuST's Avatar
Maybe you should run a little lower CR around 11:1. Instead of running CTR pistons how about the JDM P30 pistons or JDM ITR pistons. They'll probably be a little easier to tune versus the CTR pistons.
Old May 15, 2003 | 08:05 PM
1 2 NV's Avatar
12:1 is nothing, keep the CTR pistons.
Old May 18, 2003 | 05:48 PM
JoRoGSR's Avatar
i want to keep the pistons i am not sure though i need a couple more opinions
SL0-hatch
Sep 18, 2008 09:40 AM
bseries_4
Jul 26, 2007 05:06 PM
jeremy.
199
Dec 23, 2004 03:45 PM
redvic
Jun 20, 2004 07:22 PM
oMek
Jan 10, 2004 10:49 AM
