golden eagle blockguard clearences
Old May 14, 2003 | 04:03 PM
bretx0r's Avatar
Default golden eagle blockguard clearences
Since i am boring and honing the block i gave my blockguard to a shop (comptech) to install and they said that it was slightly tight on one side and loose on another side. They said they wouldnt put it in but im not about to let $100 go down the drain because of a hunch. has anyone else had a problem with htis and can give some input on it.
he said that if he was to measure with a feeler guage he'd say about .002 between the cylinder sleeve and the blockguard. should i be worried about this or would it not be that big of a deal or should i send this blockguard back to GEM and demand a different one?
Just curious thanks
Old May 14, 2003 | 04:08 PM
1.8T_EG's Avatar
Default Re: golden eagle blockguard clearences (bretx0r)
i'd like to know too... i will be installing a ge blockguard soon and wanna know... thanks...
khang77642's Avatar
the blockguard should work. On the tight side, you need to sand it down a little so it should be a little loose. Boosted hybrid should be able to tell you.
Old May 14, 2003 | 06:12 PM
bretx0r's Avatar
ttt
Old May 15, 2003 | 05:13 PM
bretx0r's Avatar
anyone else? measured it with a feeler guage.. its like .015
Old May 15, 2003 | 08:00 PM
Howitt's Avatar
just sand it down till it drops right in, dont force it
Old Jul 15, 2003 | 05:03 PM
ID_ten_T's Avatar
Default Re: golden eagle blockguard clearences (Howitt)
( back from the dead )
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Howitt &raquo;</TD></TR><TR><TD CLASS="quote">just sand it down till it drops right in, dont force it</TD></TR></TABLE>
sand down the inside or the outside? also, if it were forced in, say with a mallet, what could go wrong? also, how low should the blockguard sit? thanks.
Old Jul 15, 2003 | 05:43 PM
TeStUdO's Avatar
Default Re: golden eagle blockguard clearences (ID_ten_T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ID_ten_T &raquo;</TD></TR><TR><TD CLASS="quote">( back from the dead )
sand down the inside or the outside? also, if it were forced in, say with a mallet, what could go wrong? also, how low should the blockguard sit? thanks.</TD></TR></TABLE>
if you forced it in with a mallet it would probably make your piston sleeves egg shaped. please tell me you didnt do that. if so you probably need a bore and hone
Old Jul 15, 2003 | 11:22 PM
speeddemon's Avatar
yes! if it doesnt fit with ease do not force it! i just went through that... mine was forced at cylinder 4 on a b16... once it was all put together the car kept smoking.... the cylinder was out of round... we had to take it all apart again and get it sleeved. the car drives awesome now going on 700 miles... but NOW im reading posts about golden eagle's sleeves sinking! ahhhhhhhh!
Old Jul 22, 2003 | 01:46 PM
thid92's Avatar
can I haz?
Default Re: (hondaplex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaplex &raquo;</TD></TR><TR><TD CLASS="quote">yes! if it doesnt fit with ease do not force it! i just went through that... mine was forced at cylinder 4 on a b16... once it was all put together the car kept smoking.... the cylinder was out of round... we had to take it all apart again and get it sleeved. the car drives awesome now going on 700 miles... but NOW im reading posts about golden eagle's sleeves sinking! ahhhhhhhh!</TD></TR></TABLE>
dont worry about ur GEM sinking. i read ur post and they just changed the way they install the sleeves + i just got my block from GEM today and it looks great, i called up Vince to let him know what a great job they did. he told me if i have ANY problems which i shouldnt he will help me out. and u said ur going on 700 miles, i wouldnt worry about them sinking. good luck
Old Jul 22, 2003 | 02:55 PM
Fkned2003's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Howitt &raquo;</TD></TR><TR><TD CLASS="quote">just sand it down till it drops right in, dont force it</TD></TR></TABLE> isnt it sup. to be a press fit?? if its loose how does it keep the cyl.s from moving around?My understanding is for the best result you install and then bore and hone the block,if you install in assembled motor it will prob distort the cyl.s imo. I could be worng ,but thats how i would do it.
95gsrturbo
Oct 9, 2010 04:55 PM
p1ccoloz
May 3, 2003 05:09 PM
TurboSohc
Mar 20, 2003 08:38 PM
EEK
Aug 9, 2002 09:59 AM
1badITR
Jul 10, 2002 07:32 PM
