Will Recaro SRD work with Tenzo R rails? and bracket
Old May 14, 2003 | 01:09 PM
igotyofire's Avatar
Default Will Recaro SRD work with Tenzo R rails? and bracket
i just bought a recaro SRD, and i need to get some rails someone told me the rails from the tenzo R seats
Old May 25, 2003 | 05:27 PM
Chris1091's Avatar
Vision makes really nice brackets and sliders.
Old May 25, 2003 | 05:34 PM
JaeOne3345's Avatar
Default Re: (Chris1091)
what are the dimensions for the bottom mounting holes?
maybe u can try this.
https://honda-tech.com/zerothread?id=362733 .. pics of both Owen's original set up and my set up copying his are pictured.
all youd have to do is put your own measurements in for 13.58" measurement which is the bottom mount dimension for the sparco bottom mount seats.
here are dimensions for the srd though im not sure if the 406 is for the bolts though.
http://www.recaro-seats.com/re...s.htm
using the stock eg sliders like this puts the seat right on the rails. really low to the floor. i love it. its stiff and sturdy as hell.
Old Sep 28, 2003 | 06:34 AM
chrisir19's Avatar
Default Re: Will Recaro SRD work with Tenzo R rails? and bracket (igotyofire)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igotyofire &raquo;</TD></TR><TR><TD CLASS="quote">i just bought a recaro SRD, and i need to get some rails someone told me the rails from the tenzo R seats</TD></TR></TABLE>
Depends on the Recaros. From what i uderstand the recaro seats are supposed to bolt or already have honda brakets... you maybe able use your stock seat braket (unweld the bead that hols the fastner in the bottomw of the rail of the seat.
I want some recaros Trade you some Sparco speeds with brackets and harnesses for the the recaros with no brackets...LOL had to try
godd luck
Old Nov 14, 2004 | 08:28 PM
DOMKID's Avatar
does anybody know the answer to this question? I have the same problem.
P0411
Apr 21, 2019 06:43 PM
big.turbo.daddy
May 19, 2014 12:13 AM
bennjamin@ozhonda.com
Sep 15, 2005 04:22 PM
SimbaDogg
Jan 23, 2004 03:53 AM
HybridGSR1
Jul 25, 2003 10:18 PM
