1997 honda accord Problems?????
Old May 14, 2003 | 11:51 AM
TrblPinoy1's Avatar
Default 1997 honda accord Problems?????
ANyone out there ever had any problems with the 96-97 accord drivers side window....Id does not roll up all the way...and does not roll down.
Old May 14, 2003 | 11:58 AM
YeuEmMaiMai's Avatar
Default Re: 1997 honda accord Problems????? (TrblPinoy1)
lube it. use some graphite grease on the tracks and some poeple say wd40 on the window weather stripping seal (I would use clear silicone grease there) but WD40 is not cool for rubber or felt.
Old May 14, 2003 | 01:47 PM
TrblPinoy1's Avatar
Default Re: 1997 honda accord Problems????? (YeuEmMaiMai)
I will try that....how bout when it goes up?
Old May 14, 2003 | 02:14 PM
it should fix that problem as well after you check the switches but I think you need a new motor
Old May 14, 2003 | 02:18 PM
TrblPinoy1's Avatar
Thanks
Bidemie Godson
Honda Accord (2013 - 2015)
Apr 23, 2019 01:02 AM
Arian
Nov 7, 2016 11:55 AM
