emergency torque specs!!
i needed em for the d16z6. and thanks for the info. but there are tow different specs. you are supposed to do em all to one. then go back over em to the higher one. thanks though
Quote from Helms manual:
"Tighten the cylinder head bolts in two steps.
1st step: 30Nm (3.0kg-m, 22lb-ft)
2nd step: 73Nm (7.3kg-m, 53lb-ft)"
"Cylinder head bolts tightening sequence:
8 6 2 4 10
9 3 1 5 7"
8 6 2 4 10
9 3 1 5 7"
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foozball-26 »</TD></TR><TR><TD CLASS="quote">no the cam caps will be in inch lbs not foot. they will break if you torque them to even 10 ft lbs this is on my B18B but the d-series may be different (i doubt it.)</TD></TR></TABLE>
you're thinking valve cover bro
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika »</TD></TR><TR><TD CLASS="quote">
you're thinking valve cover bro</TD></TR></TABLE>
nope the cam bearing caps are on a B18B are 87 inch lbs, which is like 7 ft lbs
I snapped a few at 10 ft lbs so I know its not higher than that
mxmobbs
Sep 21, 2017 09:37 AM
sabremike21
Jan 3, 2009 11:55 AM
