Help-Main engine harness connector pinouts??
Old May 14, 2003 | 09:39 AM
tonydatyga's Avatar
Default Help-Main engine harness connector pinouts??
Hi-
Anybody happen to have pinouts for USDM '97 h22a4 manual main engine harness connectors? I need to splice them and can't get what I need out of the service manual. Any help appreciated, thanks for the space
Old May 14, 2003 | 11:02 AM
humtake's Avatar
Default Re: Help-Main engine harness connector pinouts?? (tonydatyga)
not sure if this will help, this is an h22a pin out pic, but not sure what year or anything:
http://tech2.hybridgarage.com/..._obd1
Old May 14, 2003 | 12:18 PM
tonydatyga's Avatar
Default Re: Help-Main engine harness connector pinouts?? (humtake)
I already have a p72 pinout. I was looking for something showing wire designations for the h22a4 main engine harness. So i can run the wires into the ecu directly. The connectors don't match or fit. Thanks anyways, it's nice to compare pinouts. Anybody else?
Old May 14, 2003 | 08:41 PM
PreludeRacer023's Avatar
tell us what your looking for and we can give you the wire colors, your question is very vague, let me know what your looking for ie tach signal or solenoid ect..peace
Old May 14, 2003 | 08:46 PM
kotetu's Avatar
Default Re: Help-Main engine harness connector pinouts?? (PreludeRacer023)
I think the point is he is looking for ALL of them.
Old May 15, 2003 | 06:05 PM
tonydatyga's Avatar
Default Re: Help-Main engine harness connector pinouts?? (kotetu)
I am pretty much looking for all of them. Gimme what you can? Much appreciated
Old May 16, 2003 | 04:07 AM
humtake's Avatar
you might want to consider buying a helms manual, it has all of that information. i dont have my scanner anymore or i would scan the pages in for you, but there are a lot of them.
Old May 16, 2003 | 07:27 PM
tonydatyga's Avatar
I have the factory manual. It doesn't label every wire... at least some of the wires change color from the ecu to the engine. If you could tell me the page numbers... I can't find it for some reason
k20rex
Oct 29, 2011 08:00 AM
hmtcrxsir
Appearance Build Threads
Jan 25, 2010 08:41 AM
hmtcrxsir
Jan 19, 2010 10:21 AM
