Need info: 4wd wagon intermediate shaft?
Old May 14, 2003 | 09:25 AM
*Boostwerks*'s Avatar
Default Need info: 4wd wagon intermediate shaft?
was it ever determined that this would fit on a regualar ZC motor?
- Does it have the same Diff spline size/count as an SI/DX?
- Does it use the same spline count/size for the axle as an SI/DX?
The reason I am asking is because:
I would like to be able to utilize equal length axles along with a Quaife in my ZC tranny.
If this doesn't work, I will most likely have to machine down the ZC intermediate shaft for the SI Quaife.
Thanks for any info!
Bryson
Old May 17, 2003 | 05:51 PM
sparkz's Avatar
Default Re: Need info: 4wd wagon intermediate shaft? (Bryson)
does the ZC have predrilled holes to mount an intermediate shaft?
I know for fact, the spline count is same as Si
Old May 17, 2003 | 07:34 PM
altoid's Avatar
Default Re: Need info: 4wd wagon intermediate shaft? (sparkz)
nothing in the manual. i'll have my engine apart in 2 weeks so if you can wait til then i'll tell you...the tranny code is L3-9xxxxxx if thats any help
Old May 17, 2003 | 07:42 PM
Default Re: Need info: 4wd wagon intermediate shaft? (altoid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by altoid &raquo;</TD></TR><TR><TD CLASS="quote">nothing in the manual. i'll have my engine apart in 2 weeks so if you can wait til then i'll tell you...the tranny code is L3-9xxxxxx if thats any help</TD></TR></TABLE>
I can definetly wait! It would be awsome if you could get me info/pics!
If you could perhaps get a pic of it before then, that would be even better! If the bolt holes are the same as the ZC then I am definetly going to try and fine one of these...
Thank you SO much.
Old May 19, 2003 | 06:15 PM
civicwagonman's Avatar
my wagon intermediate shaft and axles are basically the same as a 93 ls. so i don't think it will work with the si stuff. everythign in the awd trans is beefier than a regular si or dx trans. nothing interchanges.
the zc has the same holes on te back of the block though. most likely already threaded, and will be in the same spot as the wagon intermediate. its a direct boltin.
Old May 19, 2003 | 06:33 PM
kyle h.'s Avatar
Default Re: Need info: 4wd wagon intermediate shaft? (civicwagonman)
i just finished a sohc zc swap into my rt wagon...i was a little worried about the half shaft/intermediate shaft...but it worked out perfect.
Old May 21, 2003 | 09:57 PM
Default Re: Need info: 4wd wagon intermediate shaft? (kyle h.)
Damn.
ok thanks guy's. I was hoping it had the same splines as the SI so I could use a SI Quaife with the equal length axles.
Oh well. I guess I'm stuck with un-equal length SI's.
THANKS
loudes13
Jun 9, 2009 07:19 PM
tico
45
Sep 5, 2008 09:23 AM
racerjohn
17
Feb 29, 2008 06:30 AM
d16vtecx
Jan 6, 2007 09:20 AM
pelotudo
Aug 26, 2002 06:00 AM
