SA M2000 helmet good enough?
Old May 14, 2003 | 08:45 AM
wuhungsixxx's Avatar
New User
Default SA M2000 helmet good enough?
should be running 13s soon...
is this rating good enough?...
here is the link to the helmet:
http://www.racerwholesale.com/...ories
Old May 14, 2003 | 08:47 AM
New User
Default Re: SA M2000 helmet good enough? (wuhungsixxx)
also, are the sizing charts all the same?...or does it vary from manufacturer?...im about 23 inchs around my cranium....
Old May 14, 2003 | 01:00 PM
old guy's Avatar
M2000 is fine. Just make sure the helmet has a sticker INSIDE that denotes the Snell rating. Most have it, but there are still a few that don't. It might have it on the outside of the helmet, on the back, but NHRA tech insists on the sticker INSIDE. Usually tucked under the padding somewhere, won't pass tech without it.
By the way, an SA rated helmet would say "SA2000" instead of "M2000". More expensive. An "M" rating is good down to 7.50 et, unless otherwise stated under class rules.
Old May 14, 2003 | 01:10 PM
New User
Default Re: SA M2000 helmet good enough? (old guy)
okay my fault it was just M2000...
....so why are there two ratings "M" and "SA"....that is the difference...newbie to helmets
Old May 15, 2003 | 04:12 AM
Georgethefierce's Avatar
M= Motorcylce
SA= Special Application
falcongsr
Honda Motorcycles
26
May 19, 2004 04:08 AM
Andrew 825SM
Apr 10, 2003 03:41 PM
Tyson
Nov 6, 2002 06:45 PM
shingles
Dec 12, 2001 06:13 PM
citanest
Nov 19, 2001 12:55 PM
