How to clean foam air filter?
Old Jul 9, 2001 | 10:33 AM
ywwong's Avatar
New User
Default How to clean foam air filter?
what should I use to clean the spoon foam air filter?
Old Jul 9, 2001 | 10:52 AM
FBP_1171's Avatar
Default Re: How to clean foam air filter? (ywwong)
K&N or Uni filter cleaner. Should be able to get it at most motorcycle shops, and many performance shops. Spray it on, and rinse from the inside out. They will also have the oil for re-oiling. The K&N comes as a kit with both, but I'm not sure if you want to use K&N oil for the foam element though. Probably better off with the Uni-filter oil.
Old Jul 10, 2001 | 10:38 AM
Sam's Avatar
Sam
Default Re: How to clean foam air filter? (FBP_1171)
hey, i have a spoon filter also, i just use water to clean it, but its not working very well, and I didn't re-oil it after the wash. Do we need to reoil it? I don't think Spoon's one is pre-oil, so I guess we don't need to re-oil it after wash. Please correct if I am wrong.
Old Jul 10, 2001 | 10:42 AM
Yell00ITR's Avatar
Default Re: How to clean foam air filter? (Sam)
It is never a bad idea to oil the filter! After all, if the filter is not kept oiled, it will dry and start falling apart (not too good for your engine to inhale that!).
Call up comptech and order their foam filter oil/cleaner kit. About $10.
Old Jul 10, 2001 | 10:45 AM
Boba-Fett's Avatar
New User
Default Re: How to clean foam air filter? (Yell00ITR)
or go to Advanced Auto and buy the K&N filter cleaner/oil for $10.00
Old Jul 10, 2001 | 10:50 AM
GRM Scott's Avatar
25 Year Member
Pre-oiled just means you don't have to oil it the first time, but the oil is doing most of the work as far as filtering is concerned so you'd better re-oil after you wash out the dirty oil! as mentioned before, always rinse from the inside out so you don't pack the filth further into the filter. Uni makes most foam filter applications (comptech etc), grab a big can of cleaner and oil and be done with it.
Old Jul 10, 2001 | 10:51 AM
D's Avatar
D
the oil in the filter is actually what stops dirt/dust/debris from passing through.
after you wash your filter, the oil is no longer there. ie washing
D
Old Jul 10, 2001 | 11:17 AM
FBP_1171's Avatar
Default Re: How to clean foam air filter? (D)
Yep, the oil is what does the filtering, moreso than the foam itself.
Another thing is, plan on letting that foam AIR DRY for a while after washing (maybe as much as 1hr). ie; don't do it right before you are going somewhere...
Old Jul 10, 2001 | 11:52 AM
Sam's Avatar
Sam
Can I use the K&N oil for my Spoon filter?
Old Jul 10, 2001 | 12:02 PM
Warren's Avatar
Wrong-Way Wang
Don't use the K&N cleaner or oil on foam filters. You should use something more appropriate like ITG filter cleaner and "oil". You'll find that for foam, they don't use oil. They use a very tacky synthetic substance.
Do a yahoo search on ITG and cleaning. Should turn something up.
Warren
Old Jul 10, 2001 | 12:41 PM
FBP_1171's Avatar
No, the K&N oil is meant for the cotton K&N elements.
Budget Racer
Nov 24, 2006 01:07 AM
Alibi86
Sep 30, 2005 11:47 AM
gsr94
May 31, 2004 01:41 PM
nEoMuGen
Mar 9, 2004 12:34 PM
Teg4e
Dec 18, 2003 08:46 PM
