can motor mount cause this problem?
Old May 13, 2003 | 11:21 PM
kenethcole411's Avatar
Default can motor mount cause this problem?
my car have 108k ....everytime i turn on a/c the whole front car shake like crazy.
also when clutch engage too.is not cmooth......canyone tell me wats sup /?
Old May 13, 2003 | 11:52 PM
fastaccord94lx's Avatar
I think it's safe to say that anytime your engine shakes, and what not, that it has something to do with the motor mounts.
Old May 13, 2003 | 11:58 PM
Default Re: (fastaccord94lx)
wat should i do.......replace a stock motor mount insert or aftermarket stiffer
Old May 14, 2003 | 05:35 AM
Stew Pidasso's Avatar
Default Re: (kenethcole411)
Stop trying to chirp the tires and your clutch and motor mounts will be fine...
Old May 14, 2003 | 07:13 AM
Default Re: (Stew Pidasso)
oh no ; not u again.......damn bully<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stew Pidasso &raquo;</TD></TR><TR><TD CLASS="quote">Stop trying to chirp the tires and your clutch and motor mounts will be fine...</TD></TR></TABLE>
Old May 14, 2003 | 10:30 AM
If you don't want to spend lots of cash on aftermarket mounts, then you can find some good inserts from Energy Suspension I believe.
Old May 14, 2003 | 12:05 PM
Nick M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastaccord94lx &raquo;</TD></TR><TR><TD CLASS="quote">If you don't want to spend lots of cash on aftermarket mounts, then you can find some good inserts from Energy Suspension I believe.</TD></TR></TABLE>
or you can fill them with window weld or fiberglass long strand bondo
bl1tzk1213g
May 16, 2007 10:31 AM
tomlinson619
Feb 18, 2006 12:07 PM
ivicr
Oct 30, 2005 01:10 AM
HondaNerd
Jun 20, 2005 07:40 PM
Justin95GSR
Mar 4, 2004 11:25 AM
