Does a B16a have a fast idle thermo valve?
Old May 13, 2003 | 11:04 PM
T_Rex's Avatar
Default Does a B16a have a fast idle thermo valve?
If so, how do I go about adjusting it to lower my engine's idle?
Also, what does the IAC valve do? Thanks
Old May 14, 2003 | 04:26 AM
Xsi's Avatar
Xsi
Yes it does, located on the IM below the TB
You don't adjust it, you adjust the idle screw on the throttle body.
The IAC controls how much air goes to your engine when idling normally, the FITV adds additional air during cold starts.
Old May 14, 2003 | 07:49 AM
T_Rex's Avatar
Default Re: (Xsi)
Thanks a lot. Is there a way to check if those valves are bad?
Old May 14, 2003 | 02:23 PM
T_Rex's Avatar
Default Re: (T_Rex)
Anyone?
Old May 14, 2003 | 04:07 PM
Xsi's Avatar
Xsi
You could try taking them off and giving them a clean with carb cleaner
honda_power69
Dec 4, 2013 06:08 AM
mashguy4077
Jun 2, 2013 10:17 PM
LOL@hondas
Aug 13, 2010 11:21 AM
Maxcapacity
Jun 10, 2008 06:11 PM
ATS*Mark
16
Feb 22, 2004 01:00 PM
