H22 Knock Sensor relocation question...
Old May 13, 2003 | 10:29 PM
StickyDilJoe's Avatar
Default H22 Knock Sensor relocation question...
Hey, does anyone know if the knock sensors on the H22's can be relocated to a different part of the block? Reason is that my knock sensor was broken when the motor came and I didn't notice until after the motor and wiring was done and with it broken and where it sits, it's impossible to take it off. If the sensor is just threaded into the block, couldn't you just relocate the sensor? I've seen it done on some other cars, but I haven't heard of anyone doing it on an H22....
Old May 14, 2003 | 09:56 AM
2point6's Avatar
Default Re: H22 Knock Sensor relocation question... (StickyDilJoe)
If you remove your oil filter and disconnect the plug, you should be able to use a 27mm deep socket to remove the knock sensor and reinstall a new one. I just did it last night myself.
Old May 14, 2003 | 01:16 PM
Default Re: H22 Knock Sensor relocation question... (2point6)
Did u get the knock sensor from a junkyard or did you get a new one from the dealer?
Old May 17, 2003 | 05:10 PM
2point6's Avatar
I actually had several just laying around. If you are wondering if it was used or not, yes it was used.
Old May 19, 2003 | 11:41 PM
COMplex.'s Avatar
got anymore laying around? i need one pretty bad
Old May 20, 2003 | 12:57 AM
GimpyAccord's Avatar
Default Re: H22 Knock Sensor relocation question... (john.fuggi)
relocate the knock sensor into the nearest trash recepticle and put a ROM in with it disabled or trick the ECU with a resistor.
the nature of a cheap knock sensor and the way honda implemented them makes them virtually worthless anyway.
Old May 20, 2003 | 09:30 AM
2point6's Avatar
Yes, make me a reasonable offer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john.fuggi &raquo;</TD></TR><TR><TD CLASS="quote">got anymore laying around? i need one pretty bad </TD></TR></TABLE>
gabrielsousa
Nov 4, 2015 04:12 PM
b20forlife
Jun 24, 2010 06:04 PM
97blacklude
Jan 31, 2009 09:56 AM
bmm89
Aug 10, 2002 07:09 PM
