codes 4 and 9
Old May 13, 2003 | 08:00 PM
PhatHatch89's Avatar
Default codes 4 and 9
I have an 89 civic si and i just put a 97 sohc vtec motor in my car from a del sol. the motor runs alright it idles funny, if i hold the gas at 1000 rpm the engine has constant bog. As well I am throwing codes 4 and 9. I was wondering if anyone new the wire colors of the cyp and the ckp sensors that come out of the distsributor so that maybe i can run them straight to the ecu. the engine didnt come withe the harness so i cut the plug and i want to know if i wired it up the right way. Any help would be great thanks.
Old May 13, 2003 | 11:21 PM
bossman032's Avatar
Default Re: codes 4 and 9 (PhatHatch89)
here hope this helps~~~
Looks like your distributor is not wired up correctly.
Code 4 is **CKP Sencor**. Code 9 is **CYP SENSOR**
B11 Pink/Orange Or Orange **CYP P**
B12 White **CYP M**
B13 Pink/ Light Blue Or Orange/ BLUE **TDC P**
B14 White/Blue Stripe **TDC M**
B15 Blue/Green **CKP P**
B16 Blue/Yellow **CKP M***
I have the same problem but at 3500RPM car does not want to Go over it starts to bog.
hope this helps bro.
my aim: xbossman032x
let me know how it goes along IM me if you need any more help!!
blasterman87
Aug 28, 2009 12:23 PM
89efDUSTY
Jan 25, 2007 10:20 AM
BoRiCuA
Jun 21, 2004 03:02 PM
Slatelude
Oct 27, 2003 03:28 PM
rainforest
May 5, 2002 05:36 PM
