Leaking Headgasket??
Old May 13, 2003 | 07:54 PM
N1Spec's Avatar
New User
Default Leaking Headgasket??
Hi guys......
I found out my car was leaking oil from the headgasket last week.. ARGH!!
Anyways about 4months ago i had a mishap at the track which required my head to be taken off and new valves etc be put in. At that stage my mechanic said he had a spoon head gasket and asked whether i wanted to wack that in.... of cos i said YES! now the damn thing is leaking......... my question is: is this a consequence of improper installation or defective head gasket? does the head/block require to be machined or anything before installing a head gasket? last but not least...... do you lose compression with a leaking head gasket?
some insight would be appreciated.
Old May 13, 2003 | 07:59 PM
Hybrid ctr's Avatar
Default Re: Leaking Headgasket?? (N1Spec)
head or deck is warped???
Old May 13, 2003 | 08:25 PM
b19coupe's Avatar
Is it leaking at the rear of the head? Backwards installed head gasket leaks at the rear.
fireman mike2288
Mar 13, 2008 10:35 AM
john457
Jun 26, 2007 05:48 PM
Screamer
Apr 15, 2003 05:50 AM
filetofit
Aug 13, 2002 08:49 PM
