96 hatch w/ 96 GSR engine and motor mounts
Old May 13, 2003 | 07:47 PM
(LiTHiUm)'s Avatar
Default 96 hatch w/ 96 GSR engine and motor mounts
how hard is it to replace all the motor mounts, what will i need and how long will it take?
Old May 15, 2003 | 12:35 AM
SkyLinER's Avatar
what year is your car..I know 97' one is different
Old May 15, 2003 | 12:38 AM
B18C1EKhb's Avatar
Default Re: (SkyLinER)
it wont be that hard or take that long, what kind of mounts are u gonna use? depends on what u wanna do there is a couple different ways i can see u doing it
Old May 15, 2003 | 12:44 AM
Quik Chris's Avatar
Default Re: (B18C1EKhb)
You can do it with a jack and jackstands-- put the front of the car on jackstands and replace each mount 1 at a time by undoing the mount after jacking the motor (use a board between the bottom of the jack and the oil pan), then undo the mount you're replacing, replace it, and lower the motor.
soulkris1987
Mar 18, 2009 05:02 PM
B18PoweredCivic
Jul 18, 2003 12:46 PM
808State
Nov 9, 2001 05:26 AM
