Electrical Help needed ASAP...Please
Old May 13, 2003 | 07:18 PM
PoonHunter's Avatar
Default Electrical Help needed ASAP...Please
OK here the situation. I have a 89 CRX Si and the there is a drain or bad ground on the horn/brakelight harness. I checked it with a test light. Today I checked everything I could think off. I took out/ disconnected the brake light switch that makes the lights light when the pedal is pressed on. The test light stil lit up. I took off my steering wheel to see if it may be making contact with the horn button. Still lit up when I took the wheel off. So I figured to see if my horn works and it does. This starting to bug me because I cant drive it. The battery drains in a day unless I pull the horn/brake fuse. I was wondering if any one knows any sites that shows the wiring diagram for the horn/fuse harness on a 89 si. Also if worse comes to work anyone know how I could wire up a new brake light harness of my own? Any help please. Im stuck walking and its summer time almost. Thanks honda tech
Old May 14, 2003 | 04:41 PM
PoonHunter's Avatar
Default Re: Electrical Help needed ASAP...Please (PoonHunter)
TTT anyone..can anyone suggest maybe any grounds to check?
egdro
15
Jul 28, 2013 12:06 PM
kroze
Honda Civic (2006 - 2015)
Sep 19, 2007 04:15 PM
Cowtownchick
Jul 29, 2007 08:34 PM
G2turbo_terror
Jan 11, 2004 10:07 AM
NeoGSR
Aug 30, 2002 03:56 PM
