Stock B16a turbo dyno run....
Old May 13, 2003 | 06:53 PM
ykracing's Avatar
Default Stock B16a turbo dyno run....
Let me start by saying that everybody's opinion of what "stock" means is different.
Here's my definition: Stock sleeves, stock rods & pistons, no headwork, stock valves & springs....
I do however have gsr cams in it.
Anyways, I just got done with doing a tune on a mustang dyno... and we peaked it at 300whp@8k rpm, and 200ft.lbs. (at 11psi)
This is for my stripped down, fiberglass/lexan racecar... that probably weighs in at around... 1850-ish...
I am really pleased with the numbers, and I am excited to see how she runs this weekend... wish me luck...
Old May 17, 2003 | 11:45 AM
g2turbo's Avatar
Default Re: Stock B16a turbo dyno run.... (trboCIVIC&WRX)
damn... my b16 is not stock. JE 8.8 to 1 eagle rods blah blah but the head is stock. At 12 lbs my car only made 238 whp on a MD. but on a good note it went a 12.97 at 107.5 last night at the local track. Good luck with your setup it will haul *** in a light chassis. I have a DA and it weighs 2480 with my skinny *** behind the wheel.
Old May 17, 2003 | 12:38 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: Stock B16a turbo dyno run.... (g2turbo)
Nice, good luck, have any pics of the car and setup, just curious
Old May 17, 2003 | 11:48 PM
mitsuman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g2turbo &raquo;</TD></TR><TR><TD CLASS="quote">damn... my b16 is not stock. JE 8.8 to 1 eagle rods blah blah but the head is stock. At 12 lbs my car only made 238 whp on a MD. but on a good note it went a 12.97 at 107.5 last night at the local track. Good luck with your setup it will haul *** in a light chassis. I have a DA and it weighs 2480 with my skinny *** behind the wheel.</TD></TR></TABLE>
well some of your power went to the lower compression. seems like it makes a bit of a diff.
nice numebrs man
Old May 18, 2003 | 08:47 AM
Mr Hammond's Avatar
a/k/a Jomo
8.8:1 in a B16 is where you lost most, that and the b spec turbo. Although I have a friend with a stock B16 and same t3/t04b from the rev hard stage 2 kit that layed down 246whp @ 8psi with stock 2.5" dp, tp, and N1 exhaust. Good times though man.
Old May 18, 2003 | 02:41 PM
TurboJesse
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trboCIVIC&WRX &raquo;</TD></TR><TR><TD CLASS="quote">Let me start by saying that everybody's opinion of what "stock" means is different.
I am really pleased with the numbers, and I am excited to see how she runs this weekend... wish me luck... </TD></TR></TABLE>
Nice numbers Im aiming for 300whp on my stock b16a @10-11psi...Any info on your setup if you care to disclose?
Old May 25, 2003 | 12:11 PM
ykracing's Avatar
Default Re: Stock B16a turbo dyno run.... (Mpir3)
Ive been out of town, sorry fo taking so long to get back to this...
thanks for the postive replies, I was really happy to see the number myself.
As an update, I took it to the track and ran a best of 11.85 @ 118... I had a few low 12 runs too, but I couldnt seem to get a good 60' my best was a 1.9... on slicks.
So I need to work on my 60's because I think that this can do low 11's If I can get the think to launch.
The setup is pretty basic, gsr cams, VictorX mani, 3" dump, hondata, 550s, pwr A/L IC, and a cometic gasket...
Old May 25, 2003 | 07:04 PM
EG(6)SR's Avatar
absolutely inspiring numbers.
has it been tuned? Man, I can't wait till i get to dip my feet in forced induction this summer! Great numbers once again.
Old May 25, 2003 | 07:11 PM
HT's Biggest Loser
Can we see pictures of the car now?
Old May 26, 2003 | 10:15 AM
AllMotorDC2's Avatar
Very impressive. Must be the tuning...
Old May 26, 2003 | 11:19 AM
simple4012's Avatar
New User
Default Re: Stock B16a turbo dyno run.... (AllMotorDC2)
good numbers man.
the second post lost so much power due to the lower CR
Old May 27, 2003 | 07:59 AM
ykracing's Avatar
Default Re: Stock B16a turbo dyno run.... (simple4012)
Thanks again,
I'll get some recent pics up today/tonite....
Old May 27, 2003 | 08:04 AM
ykracing's Avatar
heres one from the track, but I'll get engine pics in a bit.... (because I know thats what you want to see)
Old May 27, 2003 | 08:22 AM
Finest's Avatar
List of mods? Looks like you're running on an W/A IC....I can't see an FMIC on that car (kinda dark pic)
But nice numbers *dyno #'s & 1/4 times*
Old May 27, 2003 | 09:01 AM
JDM92CX's Avatar
Default Re: Stock B16a turbo dyno run.... (98CTRCoupe)
What inspires me the most about this thread is that it's a B16...
Old May 27, 2003 | 01:29 PM
SergEK's Avatar
IMO those are fantastic results that speak volumes for the level of tuning and the size of the turbo used.
300whp @ 11 psi for a small 1600cc motor I am guessing that the turbo is big enough to support 500+ whp I am really surprised the stock rods held more than 250whp without letting go.....makes me wanna boost a B16
Old May 28, 2003 | 05:06 AM
ykracing's Avatar
Default Re: Stock B16a turbo dyno run.... (SergEK)
Tuning is the key... Ive got a great group of guys tuning it for me,
(here's a shameless plug for the guys at Payn Technologies ) and on the upside, we havent really pushed it yet, we got to this point in 7 pulls on the dyno.
Modified by trboCIVIC&WRX at 3:55 PM 5/28/2003
Old May 28, 2003 | 05:10 AM
ykracing's Avatar
heres the pics, sort of blurry, but you get the idea.
Old May 28, 2003 | 05:26 AM
tony1's Avatar
Very nice setup man!
Old May 28, 2003 | 05:34 AM
BoostinDC2's Avatar
Default Re: Stock B16a turbo dyno run.... (tony1)
Nice
Modified by BoostinDC2 at 6:48 AM 5/28/2003
Old May 28, 2003 | 05:39 AM
bambooluv's Avatar
really nice work man.
What did you have the liquid to air clamped to?-pdang
Old May 28, 2003 | 06:26 AM
SEFIxCivic's Avatar
clever idea on the wastegate. nice wiring
Old May 28, 2003 | 07:28 AM
ykracing's Avatar
Default Re: Stock B16a turbo dyno run.... (SEFI8LOxCivic)
Thanks again Guys...
Tony1- Ive got a couple questions for ya.. I'll IM ya'
The IC is clamped to a cup shaped bracket that has a leg that supports it up from the tranny...
the wastegate setup came from a serious creep problem, since the mani that I have was a POS, it only fed the WG from one runner... so we decided to modify it (cheaper) to allow for better control.... and it worked perfectly...
Old May 28, 2003 | 08:13 AM
HT's Biggest Loser
nice job man.
Old May 28, 2003 | 03:59 PM
SergEK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trboCIVIC&WRX &raquo;</TD></TR><TR><TD CLASS="quote">Tuning is the key... Ive got a great group of guys tuning it for me,
Modified by trboCIVIC&WRX at 3:55 PM 5/28/2003</TD></TR></TABLE>
I figured the tuning was better than some mickey mouse tuner
Maybe you can give us some info on what power levels the stock rods will hold....figuring you can probably go a few more psi I am guessing 350whp? Pretty impressive for a B16 rod.....shot peened?
Question on the wastegate...does it matter that the wastegate is only bleeding from one cyl or is the drag only setup not really affected by that? Figuring for street the bleeding of only one cyl would effect the "pulse" of the exhaust going to the turbine wheel?
Any cost figures or is this a hush hush item as far as X dollars for your particular setup and tuning?
Great job
