can a d series alt be used with a b series motor?
Old May 13, 2003 | 05:08 PM
Audipwr1's Avatar
Default can a d series alt be used with a b series motor?
i cant get my frame to bang out any further and the b series alt wont fit, but the d series will anyone ever tried this?
Old May 13, 2003 | 06:16 PM
Foowee's Avatar
Default Re: can a d series alt be used with a b series motor? (Audipwr1)
have you tried a shorter alternator belt?
Old May 13, 2003 | 06:20 PM
MADEINIRAQ's Avatar
Default Re: can a d series alt be used with a b series motor? (Foowee)
what mounts are you suing... if you can't get it to work (the B series) then something is wrong..
But yes you can fit a d series one... Just gotta do a little moddin.. actually.. if you have the cast upper alternator bracket then you probably can't do it..
Old May 14, 2003 | 05:31 AM
Audipwr1's Avatar
Default Re: can a d series alt be used with a b series motor? (madeiniraq)
it just isnt banging out further for some reason
Old May 14, 2003 | 07:59 AM
turboZChatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Foowee &raquo;</TD></TR><TR><TD CLASS="quote">have you tried a shorter alternator belt?</TD></TR></TABLE>
This is what we had to do on my ls swap went to autobarn and got a smaller belt and it worked fine just get a smaller belt and give it a try they are only 5 bucks so I would give that a try before going out and buying a new alternator
I am pretty sure the d-series will not work
Old May 14, 2003 | 08:13 AM
Flexmyrex's Avatar
Default Re: can a d series alt be used with a b series motor? (turboZChatch)
you also need to swap out the pulley on the d alternator for a b series, d pulley has two ribs and b one has three.
mayfly
Jul 22, 2010 01:09 PM
bbrian
Mar 6, 2006 09:36 PM
redcivic44
Mar 1, 2006 07:32 AM
703_Sleeper
Apr 12, 2005 06:49 AM
infamousALLMTR
Jun 3, 2002 03:52 PM
