b18c1...how much oil.
Old May 13, 2003 | 03:53 PM
HXMan's Avatar
Default b18c1...how much oil.
First off, I would have searched but OIL, is too short of a word to search for.
I just finished my b18c1 swap..I put in four quarts and it seemed low...I have over 4 quarts in now and I'm maybe 1/2 quart high..
What is the amount of oil needed when you do a full change including filter?
Thanks.
Old May 13, 2003 | 03:56 PM
Trac226's Avatar
Default Re: b18c1...how much oil. (HXMan)
3.5-4 Qts man. Pour in 3.5 qts first, turn on the engine for a few seconds. Let the oil settle and recheck your oil level.
Old May 13, 2003 | 04:04 PM
NA gs-R 05 C
Guest
Posts: n/a
Default Re: b18c1...how much oil. (Trac226)
i do an oil change every 3000 mile, n everytime i pour in 4 qts., so u should be fine.
Old May 13, 2003 | 04:14 PM
Aaron M's Avatar
Default Re: b18c1...how much oil. (NA gs-R 05 C)
i usually put in 4.5, with 4.5 it puts the level at the top dot on the dip stick, then when you start it up and get the oil flowing it usually settles in the middle of the 2 dots on the dip stick. this is on a B18c1
Old May 13, 2003 | 04:21 PM
P1mpSlap's Avatar
Default Re: b18c1...how much oil. (SilverB18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">i usually put in 4.5, with 4.5 it puts the level at the top dot on the dip stick, then when you start it up and get the oil flowing it usually settles in the middle of the 2 dots on the dip stick. this is on a B18c1</TD></TR></TABLE>
That's what I do. But lately my levels drop pretty good after a while. I gotta put another quart in. I think it's b/c my cam seals are leaking oil, but it could be more. I dunno
Old May 13, 2003 | 04:26 PM
B-Tuning.com's Avatar
Default Re: b18c1...how much oil. (P1mpSlap)
Spec calls for 4.2 US Quarts.
I put in 4 quarts, start the car, run to solid idle, shut off, let sit for 5 minutes, check oil level and top off. Works like a charm and sits dead in the center of the two level marks. :D
Old May 13, 2003 | 05:12 PM
The-LS's Avatar
Default Re: b18c1...how much oil. (B-Tuning.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B-Tuning.com &raquo;</TD></TR><TR><TD CLASS="quote">Spec calls for 4.2 US Quarts.
Old May 13, 2003 | 06:39 PM
HXMan's Avatar
Thanks for the good replys!
Old May 13, 2003 | 06:48 PM
Aaron M's Avatar
another trick is to take the valve cover breather hose, and blow on it, this will push a lot of oil out of the system. by doing this i blow a good .5 quarts of oil out that was stuck in the system
CNSK's Avatar
i usually put bout 4.5 cuase i tend to hit vtec alot and burns up my oil. if I put 4 and keep going at high rpm's 1-2 week, oil is below 2nd dot.
Old May 13, 2003 | 06:49 PM
TeamTooQuick's Avatar
4.5 is perfect...i use nothing but Mobil 1 10w-30 synthetic in mine...
Old May 13, 2003 | 07:04 PM
HXMan's Avatar
Default Re: b18c1...how much oil. (TeamTooQuick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverB18C1 &raquo;</TD></TR><TR><TD CLASS="quote">another trick is to take the valve cover breather hose, and blow on it, this will push a lot of oil out of the system. by doing this i blow a good .5 quarts of oil out that was stuck in the system</TD></TR></TABLE>
Interesting.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamTooQuick &raquo;</TD></TR><TR><TD CLASS="quote">4.5 is perfect...i use nothing but Mobil 1 10w-30 synthetic in mine...</TD></TR></TABLE>
I used to do that in my old car, until I decided it is probably better for my engine and cheaper to just change the oil with Castrol GTX every 1.5k then change with mobile one every 3 or 4k.
Old May 25, 2003 | 06:32 PM
Caully.CroSS's Avatar
huh
Old May 25, 2003 | 07:06 PM
mr.beeks's Avatar
yeap there was a thread like this before
and he mentioned that he likes to
"blow"
LOL
Old May 26, 2003 | 12:40 AM
95integrags-r's Avatar
Default Re: b18c1...how much oil. (N T R Z R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N T R Z R &raquo;</TD></TR><TR><TD CLASS="quote">
"blow"
LOL
lol
ahron
Sep 9, 2007 06:59 PM
Si Shane
Jul 6, 2006 04:59 PM
TTE TEG
Oct 21, 2005 05:54 AM
sinister357
May 24, 2005 08:04 PM
Steve26
Jul 29, 2004 05:09 PM
