so really what alternator fits??
I just got my b16 (as some of you already know) and it did not come with an alternator.. What alternator fit the b16 wil my stock one fit 94 del so 90-93 teg I just dont know???
93.5-95 Del Sol VTEC
94-5 Integra GSR
92-3 Integra GSR
do fit without any problems
not sure but 92-5 Integra alternators may also work....not 100% on it, but couldn't see why not, will need to change to your alternator pulley i think
94-5 Integra GSR
92-3 Integra GSR
First off what chassis are you putting the B16 in? If it's an EF w/ MPFI(Si/HF)use your stock engine wiring harness on the B16, and bold your EF Alternator on. You may need to swap pulleys. I did this on my 91 LS hybrid. My LS alternator was bad, so I just replaced it with my DX alternator
later
~steven
later
~steven
the swap is going into a 91 HF. If the stock alternator will work Ill just use that
Im trying to get all possible problems solved before I start wrenching.
The EF alternator may fit correctly, but it is rated for less amps than the B16A. The B16A alternator should be rated to 70-80 amps, while the EF is rated to, I believe, 60amps. HTH.
Most honda alternators will fit, but you will need the pulley from a B-series alternator. Just go into the acura dealer and tell them you need a pully for your integra alternator.
Mugencrxsir1
Sep 10, 2006 02:28 PM
