DOHC ZC Code 4
Old May 13, 2003 | 03:44 PM
tpr's Avatar
tpr
Default DOHC ZC Code 4
as i said a DOHC zc active cel 4, will start and run but will not rev past 3200 RPM (Sounds like its hitting a rev limiter). Using a funky distributer (JDM) that does not use the sensor on the exhaust cam (supposted to be inside dist). Anybody run up on this motor/dist combination? Wiring? Sensors in the dist check fine. Running a 90 SI ECU in 90 SI Civic. Where do I start?
Old May 13, 2003 | 04:52 PM
Hondasaurs's Avatar
Default Re: DOHC ZC Code 4 (tpr)
So your saying that there is no sensor on the exhaust cam in front of the distributer? Thats where the two wires (blue/yellow, blue/green) should be. Can you post a pic of it?
Old May 14, 2003 | 02:51 AM
tpr's Avatar
tpr
Default Re: DOHC ZC Code 4 (B17A Hatch)
Sorry no digital camera. But yes, it does not have the sensor on the end of the exhaust cam. It appears that it is in the distributer. It runs just not well and cannot rev past 3000-3200 RPM.
Old May 14, 2003 | 06:59 AM
Hondasaurs's Avatar
Does the distributer plug have those two wires on it?
punkracer
Nov 7, 2006 08:18 AM
luker
Aug 8, 2005 03:02 PM
boonacka
10
Jul 23, 2004 06:01 PM
*Boostwerks*
Mar 7, 2004 06:50 PM
cr-x si
Mar 1, 2003 02:35 PM
