rear lower tie bar
Old May 13, 2003 | 03:42 PM
dohc-nyne's Avatar
Default rear lower tie bar
will a rear lower tie bar that is off a 99-00 civic si fit on my 99 ls? are they the same...for instance the dc rear lower tie bar?
Old May 13, 2003 | 04:01 PM
NY_TegGSR00's Avatar
Default Re: rear lower tie bar (dohc-nyne)
I'm not sure if the two bars are interchangeable, just go to the Dc sports website and compare the 2 part numbers. If they are the same, you're good to go. BUT there's one problem...getting the LTB in the Teg is rediculous! I have tried a few times to install the Benen rear LTB on my 00GSR and have had no luck. When you take out any 1 of the bolts the suspension arm twists, making reassembly virtually impossible. Benen tells me that you will have to dissassemble the rear suspension to put it in. GOOD LUCK MAN (get a hammer ready)
sol_1
Feb 25, 2007 05:30 PM
JoshuaVTEC
Suspension & Brakes
Jan 21, 2005 01:35 PM
RUBZERK
Mar 25, 2004 10:00 AM
Heinz57
11
Dec 27, 2002 08:13 AM
