Golden Eagle Mfg. Dry Cell Battery!!!!
We just had a brilliant idea, why not supply you guys with a top of the line, mil-spec battery for use in drag race, road race, street and off-road use? Well, we are now doing just that.
Golden eagle Mfg. proudly announces the release of it's Wicked Power battery!!
Specs:
12V Valve regulated sealed lead acid battery
800 Cold Cranking Amps
Corrosion free
Can be mounted in any position
Delivers 1500 amp peak discharge for a full 8 seconds
Size:
6 13/16" High
9 3/4" Long
5 3/16" Wide
Available soon. Call for details and pricing!!! (909) 592 - 4311
Modified by GoldenEagleMfg.com at 11:57 PM 5/13/2003
Specs:
Corrosion free
Size:
6 13/16" High
9 3/4" Long
5 3/16" Wide
damn you ... right when I went a jsut bought the 16v turbostart from summit racing you come out with this
bet the price is cheaper for your battery too !!!
greg
greg
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CHEETAH »</TD></TR><TR><TD CLASS="quote">damn you ... right when I went a jsut bought the 16v turbostart from summit racing you come out with this
greg</TD></TR></TABLE>
stick wit hthe 16volt setup its the way to go.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaswaper »</TD></TR><TR><TD CLASS="quote">how heavy are they? </TD></TR></TABLE>
Yes, how heavy?
Yes, how heavy?
Turbostart 16v batterys -Do you guys just run it straight after charging it for the track? Do u use any voltage regulators at all or just run it straight with full juice!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOUNDEFFECTS »</TD></TR><TR><TD CLASS="quote"> Turbostart 16v batterys -Do you guys just run it straight after charging it for the track? Do u use any voltage regulators at all or just run it straight with full juice!</TD></TR></TABLE>
we charge every round the MSD boxes require you to step down to 12 volt especially on there MSD 10 box
It is identical to the Holley battery, same manufacturer, but Holley got cut off due to some reasons unknown and the contract was given to us!!! Holley now uses a different battery. Price comparable batteries and you will see that our price is very competitive!!!
Modified by GoldenEagleMfg.com at 10:13 PM 5/14/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">
we charge every round the MSD boxes require you to step down to 12 volt especially on there MSD 10 box </TD></TR></TABLE>
the stock alternator puts out 14 volts , so 16 is fine for the MSD and all the other stuff in the car (gauges , ECU , relays ect...)
how heavy are they?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vu »</TD></TR><TR><TD CLASS="quote">
Yes, how heavy?</TD></TR></TABLE>
25lbs??
how heavy are they?
25lbs??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic disobedience »</TD></TR><TR><TD CLASS="quote">Quote, originally posted by hondaswaper »
how heavy are they?
25lbs??</TD></TR></TABLE>
Very doubtful. Probably more like 50lbs...
how heavy are they?
Hey 200 plus bucks for a sealed battery, is quite a a bit, I should know I worked in batteries for a couple years, Im not gonna say the name of the company but its the #1 replacement battery brand in the US, I mean for $200 dollars you are basically getting a 12v group 34 with 800cca and its sealed and there are several batteries like this on the market and the company who makes that battery makes it for other companies as well. im not saying its a bad battery im just saying before you drop money like that in a simple battery thats no different than a sealed lead acid. just shop around. I know a guy who had purchased what he thought were lightwieght batteries and came to find out they were junk because they had no reserve cranking power (how long it can supply 12volts) and while trying to fire the car up he had to switch because the batteries went dead, Optima makes a good battery for $150 and its as good if not better than the dry cell that golden eagle is offering and its a mere 40lbs as well. me i have never used a dry cell or a sealed battery in my vehicles and I have never had 1 problem. i know a guy who has a 600hp honda and he uses the stock size group 51 on his car and its a JCI brand lead acid. Final thought; is 200 plus dollars really a deal for a battery that is really not all that great to begin with. In all reality its a 125 dollar battery with a 220 dollar sticker.
Modified by NuclearTaco at 5:14 AM 5/15/2003
