tire size
Old May 13, 2003 | 12:41 PM
B.'s Avatar
B.
400 HP Club
Default tire size
No flames plz, honest question...... If i use a 2/2.3 inch drop on my civic and run 205/50/15 will I have a problem rubbing? or should I go with a 195/50/15? thank you much.
Old May 13, 2003 | 12:42 PM
SlippylesKB's Avatar
Default Re: tire size (THE B)
I just put 205/50-15's on my car with a 2.5f 2.25r drop and no issues at all. Love 'em. You will be fine
Old May 13, 2003 | 12:46 PM
B.'s Avatar
B.
400 HP Club
Default Re: tire size (SlippylesKB)
ok i'll go ahead with ordering the tires thanks a bunch.....
Old May 13, 2003 | 12:50 PM
Mocky57's Avatar
with 15's, you should be ok.... with a 2/2.5 inch drop, I'm assuming you've had the camber properly adjusted as well. 205/50-15's? Getting Azenis?
Old May 13, 2003 | 12:54 PM
B.'s Avatar
B.
400 HP Club
Default Re: tire size (Mocky57)
I have a camber kit for the car but haven't played with it yet. I wanted to wait until I finished the 4 wheel disc and put the new suspension in. I ditched my 17 white revo's in favor of the rota's.....I had too... I also just picked a sweet set of real carbon fiber F1 mirrors for it, not sure how they will look but I hope there trick.
Old May 13, 2003 | 01:36 PM
qbsi's Avatar
i'll let you know as soon as i get my Azenis.
unless you have the tires, good luck getting them because everyone is on back-order for 3 to 4 weeks.
I ordered my tires about a week ago and i was told the tires will be shipped in two weeks maybe.
I really dont think you're gonna have problems. I've heard there might be slight rubbing in the inside when your front wheels are turned all the way.
Old May 13, 2003 | 01:39 PM
4DeepCivic's Avatar
Default Re: tire size (qbsi)
Have you thought about the off-set of the wheels?
Old May 13, 2003 | 02:38 PM
qbsi's Avatar
Default Re: tire size (4DeepCivic)
i am going to be using my stock si rims.
Old May 13, 2003 | 03:07 PM
LSiTurbo's Avatar
i have an 00 Si lowered 2in. with %Zigen springs and run a 225/50/15 BFG in the front with no probs, so i would assume you wouldnt either. also a 205/50/15 in back, but of course thats no problem.
Old May 13, 2003 | 06:57 PM
B.'s Avatar
B.
400 HP Club
Default Re: tire size (LSiTurbo)
the offset is 6.5.........
Old May 13, 2003 | 07:38 PM
You'll be fine w/ your rotas... I'm running rota group n's with my setup. and all 15's are the same.
Old May 13, 2003 | 07:59 PM
h22 civ's Avatar
The offset's not 6.5 thats the rim width, usually 38mm, 40mm.
shahriar35
Dec 16, 2014 08:07 AM
ezcape
May 15, 2011 04:52 AM
rexfan
Mar 16, 2007 10:31 AM
orangeturbogsr94
Jan 23, 2005 10:17 AM
LS Teg
Aug 6, 2002 08:06 AM
