if i swap my tranny to a si will i have to change the ecu or anything, its a vx
Old May 13, 2003 | 11:50 AM
93egbeau's Avatar
Default if i swap my tranny to a si will i have to change the ecu or anything, its a vx
if i were to swap tranny to an si wouldnt i have to change my vx ecu?? t hanks
Old May 13, 2003 | 12:00 PM
piscorpio's Avatar
Default Re: if i swap my tranny to a si will i have to change the ecu or anything, its a vx (93egbeau)
I am almost 100% certain, that you do not have to change your ECU. If I were wrong on this, I would be very surprised. Only reason I don't give you a definite no, is because I have not done it personally.
Old May 13, 2003 | 12:17 PM
VXpride's Avatar
Default Re: if i swap my tranny to a si will i have to change the ecu or anything, its a vx (piscorpio)
Straight forward swap... everything bolts right up. Just a little time cosuming, i would recommend a new clutch, pressure plate, pilot/throw out bearing and resurface your flywheel if it needs it. oh and you don't need a different ecu.
Old May 13, 2003 | 12:20 PM
93egbeau's Avatar
Default Re: if i swap my tranny to a si will i have to change the ecu or anything, its a vx (VXpride)
awesome thanks man hey how hard is to install a si intake manifold to my vx and is it expensive? t anks
i-want-a-crx
10
Jun 26, 2008 03:49 PM
89txrex
Jul 20, 2005 04:51 AM
johnclaunch
Jul 2, 2004 03:26 AM
Unit02VXHatch
Jun 26, 2004 02:43 PM
Import13alla
May 28, 2004 06:37 AM
