ZC-Teg Ecu-Code 10??
Old May 13, 2003 | 11:36 AM
Ronin Panda's Avatar
Default ZC-Teg Ecu-Code 10??
Hey whats up-
I just finished my ZC install on my 89 std hatch..i have a 89 teg ecu.
i just got the battery hooked up as my last thing to do and i checked the ecu and its throwing a code 10. anybody know what this code means? and if you could answer that for me and possibly link me up with a list of codes so i can check them myself from now on...thanks dudes and dudettes.!
edit: also..when i try to find codes ...do i look for acura codes becuase i have a acura ecu? or does it go by motor?
Old May 13, 2003 | 02:04 PM
carsaregood's Avatar
Default Re: ZC-Teg Ecu-Code 10?? (Touge Panda)
http://www.c-speedracing.com/faq/05.php
not sure if the teg ecu i sent you applies to these.. but maybe it'll help. goodluck getting that thing started!
Old May 13, 2003 | 02:29 PM
Hondasaurs's Avatar
Code 10 IAT. The sensor is located in the intake manifold. It should be a white sensor with two screws in it. The plug is a two wire plug with a red/yellow and green/white wire on it. 1st pull the sensor out and clean it. Make sure there are no cracks in it before you put it back in. Pull the positive off the battery to reset your ECU.
codybuRr
May 14, 2012 09:09 AM
jonathan13
Jun 24, 2009 08:39 AM
jonathan13
Apr 20, 2009 06:21 AM
BoRiCuA
Nov 23, 2004 06:49 PM
USDM 4G VTEC
Sep 12, 2002 01:37 PM
