wiring diagram for gsr cluster in eg
Old May 13, 2003 | 10:46 AM
Nextelbuddy's Avatar
Default wiring diagram for gsr cluster in eg
well i searched and found a useful thread https://honda-tech.com/zerothread?id=502054 but in that thread is said that he had wiring problems and the diagram wasnt complete. i was just curisous to know if soe one could post a link to a good site that has a wire for wire and color for color diagram for the gsr cluster in the eg. i am sorry for asking this again as i have seen this post so many times too but i have yet to read a post about this that had a link to a good site with the exact wire for wire and color for color diagram for this project. thanx for any help
Old May 13, 2003 | 11:19 AM
Default Re: wiring diagram for gsr cluster in eg (nextelbuddy)
ok i found the wiring diagram for the gsr cluster. but now i dont know where to find the wiring diagram for the 93 civic cluster. can anyone help me out with a link or something please
Old May 13, 2003 | 11:29 AM
SlippylesKB's Avatar
http://www.geocities.com/cinq1....html
Try that out... I haven't done mine yet so I don't know how well those work. But the guy said everyhting worked for him. I still have to wait for a free car to drive around when the cluster is out.
Old May 13, 2003 | 12:14 PM
Default Re: wiring diagram for gsr cluster in eg (SlippylesKB)
wow thanx man that helps out a lot. now al i need is a gsr cluster. lol thanx again for your help
Old May 13, 2003 | 12:16 PM
no problem, when you buy your cluster make sure they send the plugs that plug into the back of the cluster. You will need those. That is another thing that is holding me back from doing this project, need to find some plugs
Old May 13, 2003 | 12:23 PM
in these pix of the cluster off ebay the cluster has 3 plug slots but the diagram instructions i got off that site u gave me only has 2 plug diagrams. i dont understand.. do u know?
Old May 13, 2003 | 12:36 PM
I'm sorry, but I can't tell ya... like I said I haven't tackled the project myself. I can only ASSUME that the 3rd plug is a plug and play... maybe having to do with the odometer and hoopla like that.
Old May 13, 2003 | 12:42 PM
possibly but in this picture below i found u can clearly see that that plug slot remains empty even in the integra weird isnt it.
Old May 13, 2003 | 12:49 PM
Well on EVERY single page I have on how to do this, they don't even make mention of the 3rd plug. SOOO I wouldn't sweat it. Just make sure you get everythign you can from the Integra and have at it. Also, when you take your stock cluster out, you could find that it's not even used on the EG but I'm not sure. Just a guess... once again.
Old May 13, 2003 | 12:54 PM
thanx for your advice
Old May 13, 2003 | 12:56 PM
No problem, good luck
Old May 13, 2003 | 01:02 PM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlippylesKB &raquo;</TD></TR><TR><TD CLASS="quote">Well on EVERY single page I have on how to do this, they don't even make mention of the 3rd plug. SOOO I wouldn't sweat it. Just make sure you get everythign you can from the Integra and have at it. Also, when you take your stock cluster out, you could find that it's not even used on the EG but I'm not sure. Just a guess... once again.</TD></TR></TABLE>
Actually i started this swap a few days ago, but i need a new cluster before i can continue.
When you take out the EH2(EG) cluster there are only 2 big plugs. Then there is a small white and a small yellow plug.
Old May 13, 2003 | 01:05 PM
Default Re: wiring diagram for gsr cluster in eg (Hatchy-Ownzjo0)
yea i figured that the smaller ones are SRS and dimmer switch. good call
Old May 13, 2003 | 01:57 PM
743power's Avatar
I looked on the back of a gsr the other day, and there is 4 plugs, so one must be unused and the other is not shown on that pic above.
Old May 13, 2003 | 02:02 PM
andrew dc's Avatar
follow this diagram that you could have found if you did a search and it will work correctly.. i have had it done since Feb and no problems at all...
teg's blue left side plug (13 pins)
1. blu tach signal
2. grn/org check engine indicator
3. yel/red oil pressure switch
4. NOT USED NOT USED
5. wht/blu charge indicator
6. NOT USED NOT USED
7. yel/grn coolant temp
8. blk ground
9. red/blu cruise (if you have cruise)
10. yel hot
11. NOT USED NOT USED
12. pink maintenance (not used)
13. NOT USED NOT USED
teg's right side blue plug (16 pins)
1. grn/red e.brake signal
2. red/grn high beam
3. grn/yel right turn
4. grn/blu left turn
5. NOT USED NOT USED
6. blk/yel power
7. red/blk power
8. red power
9. blu/red abs (not used)
10. grn trunk switch
11. org vehicle speed sensor
12. NOT USED NOT USED
13. blu/wht low fuel (not used, cant be used w/ out integra gastank and sensor)
14. yel/wht fuel gauge
15. lt grn/red door switch (not used, can be used w/ extra wiring to the doorpins)
16. red/blu seat belt
civic's left side grey plug (12 pins)
1. yel/wht fuel gauge
2. yel/blu vehicle speed sensor
5. wht/blu charge
6. yel/red oil pressure switch
7. NOT USED NOT USED
8. blu tach signal
9. NOT USED NOT USED
10. blk/yel power
11. red/blk power
12. red power
civic's right side grey plug (10 pins)
1. red/grn high beam indicator
2. grn/red e brake signal
5. grn/org check engine indicator
6. blk ground
8. yel hot
9. grn trunk switch
10. blu/wht seat belt
on the teg right side plug for the fuel guage.. I had a pin in the 13 spot and had to move it to the 14 spot... other than that it was perfect....
Old May 13, 2003 | 02:04 PM
Default Re: wiring diagram for gsr cluster in eg (CRX25)
in the post above is that for gsr cluster into a 92-95 civic or is that for gsr cluster into a 88-91 crx/civic? i ask because of your screenname
Old May 13, 2003 | 03:02 PM
andrew dc's Avatar
yes sir it is.. I was answering your question for a gsr cluster in an eg... I did it myself in my eg...
thanks
andrew
Old May 13, 2003 | 03:21 PM
Default Re: (l Hybrid l)
You need the plugs to plug in the back of the Gauge Cluster, the civic's do not fit, hence why you have to wire up the GSR cluster to work.
Old May 13, 2003 | 03:59 PM
andrew dc's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by l Hybrid l &raquo;</TD></TR><TR><TD CLASS="quote">Can't i just snip the wires off? then tape it to the color i need to match it to and tape it with electrical tape?</TD></TR></TABLE>
sodder the wires.. and they dont all color match.. most do.. about 80%
then what do you do? go to the list....
Old May 14, 2003 | 03:33 AM
Micro's Avatar
excellent post.
edit: question answered
Modified by Micro at 8:46 AM 5/15/2003
Old May 14, 2003 | 03:42 AM
HuskerHybrid's Avatar
Default Re: wiring diagram for gsr cluster in eg (Micro)
my bros:
Old May 14, 2003 | 04:06 AM
CXHatchback's Avatar
Default Re: wiring diagram for gsr cluster in eg (HuskerHybrid)
I just wired up mine and it works pretty well, although the abs light stays on and the speedo is late. But other than that I used that wiring list a few posts up and it worked no problem. Actually I had trouble with the last 2-3 wires, but all in all I think it's fine. I just found out the LS cluster I have doesn't work right, so I'm waiting on my integra cluster to come in.
Oh, and I used T-taps to connect mine.
Old May 14, 2003 | 04:23 AM
ekhatchhybrid's Avatar
Default Re: wiring diagram for gsr cluster in eg (CXHatchback)
what i need is the wiring diagram for a gsr cluster into a 96 ek, somebody please help me on this if you can find some diagrams
Old May 14, 2003 | 05:21 AM
Default Re: wiring diagram for gsr cluster in eg (ekhatchhybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekhatchhybrid &raquo;</TD></TR><TR><TD CLASS="quote">what i need is the wiring diagram for a gsr cluster into a 96 ek, somebody please help me on this if you can find some diagrams</TD></TR></TABLE>
Courtesy of FifthGearOnline:
http://www.fifthgearonline.com...r.htm
Here's another: http://patriot.net/~merritt/gauge.html
Good luck
Old May 14, 2003 | 05:58 AM
SprayinCX's Avatar
Integra Blue Left Side Plug (13 pins)
1. BLU - Tach signal
2. GRN/ORG - Check engine indicator
3. YEL/RED - Oil pressure switch
4. -
5. WHT/BLU - Charge indicator
6. -
7. YEL/GRN - Coolant temp
8. BLK - Ground
9. RED/BLU - Cruise control (if you have cruise)
10. YEL - Hot
11. -
12. PINK - Maintenance (not used)
13. -
Integra Right Side Blue Plug (16 pins)
1. GRN/RED - E-Brake signal
2. RED/GRN - High beam
3. GRN/YEL - Right turn
4. GRN/BLU - Left turn
5. -
6. BLK/YEL - Power
7. RED/BLK - Power
8. RED - Power
9. BLU/RED - ABS (not used)
10. GRN - Trunk switch
11. ORG - Vehicle speed sensor
12. -
13. BLU/WHT - Low fuel (not used)
14. YEL/WHT - Fuel gauge
15. LGT. GRN/RED - Door switch (not used)
16. RED/BLU - Seat belt
Civic Left Side Grey Plug (12 pins)
1. YEL/WHT - Fuel gauge
2. YEL/BLU - Vehicle speed sensor
5. WHT/BLU - Charge
6. YEL/RED - Oil pressure switch
7. -
8. BLU - Tach signal
9. -
10. BLK/YEL - Power
11. RED/BLK - Power
12. RED - Power
Civic Right Side Grey Plug (10 pins)
1. RED/GRN - High beam indicator
2. GRN/RED - E-Brake signal
3. -
4. -
5. GRN/ORG - Check engine indicator
6. BLK - Ground
8. YEL - Hot
9. GRN - Trunk switch
10. BLU/WHT - Seat belt
_______
thats for a gsr into a 92-95 civic
i used this and i have had no problems at all
