Gutting my catalytic converter....HELP !!
Old May 13, 2003 | 10:19 AM
MikeTV
Guest
Posts: n/a
Default Gutting my catalytic converter....HELP !!
I want to gut my converter, and I had a few questions about it:
1. What is the difference between an OBD1 and an OBD2 catalytic converter ?
2. Will this affect the car negatively in any way ?
3. How much HP will I gain ?
4. Can I do it myself , and if so...how ??
Thanks in adavnce for your input ....
Old May 13, 2003 | 10:24 AM
WiggiE's Avatar
New User
Default Re: Gutting my catalytic converter....HELP !! (Eclipse spanker)
1. None that I'm aware of besides having an O2 bung in the OBD2.
2. It will throw a check engine light due to having no catalytic material anymore.
3. Not sure exactly how much HP, it'll be a couple at least. But it really depends on your mods.
4. Yes you can do it yourself. It's not always easy though. Basically you take like a long screwdriver and hammer the catalytic material out.
Personally, for the time it is going to take you to do this, I'd buy a test pipe. They are inexpensive.
Old May 13, 2003 | 10:29 AM
dohc-nyne's Avatar
i belive its gonna affect ur car in a negative way my freind has a 00 si obd2...he gutted his cat and he has i/h/piping....its threw alot of codes including all cylinders misfiring....ur cat sensor is gonna pick up too much pressure and not know how much fuel to add to all that air....u need to get a o2 simulator or just get a hi flow cat...
Old May 13, 2003 | 10:34 AM
dip-set's Avatar
Default Re: Gutting my catalytic converter....HELP !! (WiggiE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WiggiE &raquo;</TD></TR><TR><TD CLASS="quote">1. None that I'm aware of besides having an O2 bung in the OBD2.
Personally, for the time it is going to take you to do this, I'd buy a test pipe. They are inexpensive.</TD></TR></TABLE>
#2..will a carsound throw a code also...being that there is no catalyitc material or is there minimal material still in a high flow...sorry for the thread jack but i thought its a decent question..
Old May 13, 2003 | 10:40 AM
dohc-nyne's Avatar
the carsound wont throw a code...it still has inlet and outlet material...just less of it...so a lil more air flows through....the difference is like 1 hp if that.....plus it wont polute out beautifull air..... as much
Old May 13, 2003 | 10:41 AM
WiggiE's Avatar
New User
Default Re: (dohc-nyne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohc-nyne &raquo;</TD></TR><TR><TD CLASS="quote">he gutted his cat and he has i/h/piping....its threw alot of codes including all cylinders misfiring</TD></TR></TABLE>
Gutting your cat will throw a code. But it will only throw ONE code.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohc-nyne &raquo;</TD></TR><TR><TD CLASS="quote">ur cat sensor is gonna pick up too much pressure and not know how much fuel to add to all that air....u need to get a o2 simulator or just get a hi flow cat...</TD></TR></TABLE>
The "cat sensor" (correctly labeled the 02 sensor) does not read pressure. The A/F ratio is not gotten from the 2nd 02 sensor, but the 1st, which is before the catalytic converter. You don't need an 02 simulator unless you don't want to deal with having a check engine light all the time. It has no affect on the car or performance as it is just telling you to replace the cat.
dip-set's Avatar
thank u
Old May 13, 2003 | 10:44 AM
ragejed's Avatar
Default Re: (WiggiE)
******* noob, just leave and off your self. You have to be a ******* moron to gut your cat, or to run a test pipe. Woah, few free horepower really worth the damage to the enviroment? Just buy something else to make more power. Stop ruining the world that others live in. to you for being so ******* stupid. JUST LEAVE
Old May 13, 2003 | 10:47 AM
WiggiE's Avatar
New User
Default Re: (ragejed)
ragejed: I agree that you shouldn't run a test pipe or gutted cat. But he wasn't asking that and you have no idea whether he actually drives his car on the street. It may be a track only car. Either way chill the fawk out and have a
Old May 13, 2003 | 10:49 AM
ragejed's Avatar
Ohhh, So cars on a track dont pollute? news to me.. I am chill, I just hate that people need to gain a few HP on the cost of other. In this case, the enviroment. Just spend the money, and get a high flow cat.
dohc-nyne's Avatar
well if u gut it also ur just gonna burn out ur o2 sensor...
allmotorls95's Avatar
just buy i high flow cat...
Old May 13, 2003 | 10:51 AM
Cone's Avatar
I agree
Old May 13, 2003 | 10:55 AM
WiggiE's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohc-nyne &raquo;</TD></TR><TR><TD CLASS="quote">well if u gut it also ur just gonna burn out ur o2 sensor...</TD></TR></TABLE>
d00d what are you talking about??? You didn't know what you were talking about earlier, and you probably have no clue now. I would love to hear your technical explanation as to why your 02 sensor is going to burn out?
Old May 13, 2003 | 10:58 AM
dohc-nyne's Avatar
probably the same reason why ur tailpipe gets black....and doooood my freind has already accomplished it....it might not happen to everyone....but it happened to him..so in closing....if ur gonna do something do it rite....dont cut corners...for one hp
Old May 13, 2003 | 11:03 AM
WiggiE's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohc-nyne &raquo;</TD></TR><TR><TD CLASS="quote">probably the same reason why ur tailpipe gets black....and doooood my freind has already accomplished it</TD></TR></TABLE>
y0 mang, my bad fo dissin' on y0 homies ride. He bez rite.
You are sofa king we todd did. "The same reason why ur tailpipe gets black" ROTFLMAO. Your tailpipe can get black whether or not your cat is gutted. I think it's funny how ragejed is calling the maker of this thread the noob, when in actuality you are the we todd did n00b.
Old May 13, 2003 | 11:54 AM
dohc-nyne's Avatar
well listen to wiggie then since he has nothin better to do than try and sound smart...
Old May 13, 2003 | 11:56 AM
dohc-nyne's Avatar
i mean ive only seen it in person wut do i know...???? lol
Old May 13, 2003 | 12:03 PM
StyleTEG's Avatar
How many HP will you gain? probably none
its still an ungodly bottleneck, because of the diameter not the element inside.
Old May 13, 2003 | 12:08 PM
dohc-nyne's Avatar
thats why people insist on gettin custom test pipes so u can port match it with ur piping
Old May 13, 2003 | 12:12 PM
Rory Breaker's Avatar
I can see this thread is getting out of hand already...
Eclipse Spanker, welcome to HT. You got your answers for the most part.
I wouldnt gut the cat. I would get a Carsound. If youre going to do it, do it right. I wouldnt ruin the stock cat that you can sell, it wont help much in terms of performance, and Ive *heard of* gutted cats resulting in damaged 02 sensors. Never experienced it, but I have seen peoples 02 sensors subsequently fail after running a test pipe or gutted cat.
Good luck.
Old May 13, 2003 | 12:14 PM
dohc-nyne's Avatar
and thats wut happend to my freinds...but i guess no one wants to belive...thank new gsr driver
Vtecattack
Mar 21, 2006 09:20 AM
1hotcivicSi
23
Mar 25, 2004 12:15 PM
Electron Si
15
Feb 11, 2004 02:57 PM
MikeTV
May 13, 2003 12:52 PM
paulyman
Aug 26, 2002 04:40 PM
