01 GSR w/ i/h/e next mods .. please help
Old May 13, 2003 | 10:10 AM
whitenameseboi's Avatar
Default 01 GSR w/ i/h/e next mods .. please help
i have currently on my GSR
*AEM cai
*Greddy 4-2-1 header
*Greddy Evo cat back exhaust
*** as far as the motor is concerned everything else is STOCK!
*** as you can see, my mods make my car smog legal
*** my question is this,
***What modifications can I do to get more power but stay legal. (i want to stay Normally Aspirated).
Thanx for all your advice. Brian
*to find the meaning of life, you first must live a life of meaning*
Old May 13, 2003 | 10:13 AM
Havokmkr's Avatar
Default Re: 01 GSR w/ i/h/e next mods .. please help (whitenameseboi)
Naturally aspirated. Anyway, you could get some cams and cam gears, new pistons(ITR or CTR), a carsound cat, new rods, crank, etc. There is an abundance of performance parts for NA engines. You just have to decide what your goal is and how much you want to spend.
Old May 13, 2003 | 10:16 AM
neo1z's Avatar
Default Re: 01 GSR w/ i/h/e next mods .. please help (Havokmkr)
Carsound cat
Old May 13, 2003 | 10:20 AM
drumking15's Avatar
i 2nd the carsound cat..you stock cat is creating a bottle neck inbetween your free flowing exhuast parts...then id recomend a valvetrain upgrade and some skunk2 stg 1 cams w/ cam gear and a vafc and tune that sucka...w/ the cams id also recomend gettin a single runner im...like a skunk2, but when doin that youll have to ditch your orginal aem cai and buy a itr cai...that at least 1500 worth of mods to get decent power about 170ish to the wheels...good luck
Old May 13, 2003 | 12:00 PM
StyleTEG's Avatar
Default Re: (drumking15)
Carsound cat
Keep in mind that cats and test pipes are measured ID, not OD like collectors and exhaust. Make sure you get the right sized one for your system.
Your collector is 2" and your exhaust is 60mm (2.36)
Old May 13, 2003 | 01:17 PM
NA gs-R 05 C
Guest
Posts: n/a
Default Re: (StyleTEG)
get a fuel pressure regulator.
Old May 13, 2003 | 01:18 PM
Thrillhouse's Avatar
Are all these things you guys are mentioning smog legal? I didnt think cams were smog legal? I know that certain cats in california are not smog legal. Where in lake forest are you bro im in Lake Forest too!
Old May 13, 2003 | 01:20 PM
00VTEC's Avatar
nobody cares about the suspension??
spring + shock combo or
nice coilover
and itr rear sway bar
Old May 13, 2003 | 01:39 PM
M-Type's Avatar
Default Re: 01 GSR w/ i/h/e next mods .. please help (00VTEC)
start looking around for an OBD1. You can put your stock ecu back on when you need to smog it
Old May 13, 2003 | 01:49 PM
Seedc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00VTEC &raquo;</TD></TR><TR><TD CLASS="quote">nobody cares about the suspension??
nice coilover
and itr rear sway bar </TD></TR></TABLE>
I think he wants power mods as he mentioned he wants to keep his car smog legal.
pretty much what was mentioned above. cams skunk2 im carsound cat. Ill eventually go that route after I find my damn jdm itr 4-1
Old May 13, 2003 | 01:50 PM
StreetRacnGsR
Guest
Posts: n/a
Default Re: 01 GSR w/ i/h/e next mods .. please help (M-Type)
Thats what i did for my 98 GSR was a chipped odb-1 ecu and i had a test pipe. i just took in and out for Smog. get a clutch and flywheel too. they make a big differance.
GreenR
Aug 9, 2003 03:51 AM
gribbs
Apr 11, 2003 03:53 PM
acatak
Feb 19, 2003 06:34 AM
joltx12
Sep 4, 2002 03:19 PM
96_GSR
Jun 18, 2002 07:15 AM
