How can I chirp 4th and 5th gear?
Old May 13, 2003 | 09:10 AM
BillWalton1
Guest
Posts: n/a
Default How can I chirp 4th and 5th gear?
Yo I got a 99 EBP Si with a ACT clutch. Why cant I chirp 4th and 5th gear?
Old May 13, 2003 | 09:12 AM
JALOP B16's Avatar
Default Re: How can I chirp 4th and 5th gear? (BillWalton)
I can chirp 4th in my crx. But why?
Old May 13, 2003 | 09:17 AM
Chris y0!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BillWalton &raquo;</TD></TR><TR><TD CLASS="quote">Why cant I chirp 4th and 5th gear?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BillWalton &raquo;</TD></TR><TR><TD CLASS="quote">I got a 99 EBP Si</TD></TR></TABLE>
Old May 13, 2003 | 09:19 AM
SlippylesKB's Avatar
Default Re: How can I chirp 4th and 5th gear? (Chris y0!)
sell your car now
Drews Bitch's Avatar
maybe your V-tek isn't working or you need som NAWZ y0!
Old May 13, 2003 | 09:20 AM
Nextelbuddy's Avatar
yea what he said just kidding man um why would you want to chirp 4th and 5th? spinning of anytire is not good for the tire itself or traction. if anything you woudl want it to just grab but its all what you want ..
Old May 13, 2003 | 09:23 AM
Tony Starks's Avatar
Default Re: How can I chirp 4th and 5th gear? (nextelbuddy)
You won't be here long.
Old May 13, 2003 | 09:35 AM
built562's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BillWalton &raquo;</TD></TR><TR><TD CLASS="quote">Yo I got a 99 EBP Si with a ACT clutch. Why cant I chirp 4th and 5th gear?</TD></TR></TABLE>
try to chirp in reverse. just gun it in 1st and throw it in reverse!!!
but you should not chirp 4th or 5th anyways.
Old May 13, 2003 | 09:39 AM
KENLUDE97's Avatar
Default Re: How can I chirp 4th and 5th gear? (akumaracer)
the reason that you are not "chirping" the tires in 4th and 5th gear is that you don't have over 500whp! :slap: :slap:
Old May 13, 2003 | 09:40 AM
Chris y0!'s Avatar
Default Re: (GSRslowandswap)
i can bark 18th on my mountain bike.
which will smoke an EM1 easily.
Old May 13, 2003 | 09:42 AM
Ivan's Avatar
senior gold member
because you didn't buy a FBP SI
Old May 13, 2003 | 09:44 AM
.paul's Avatar
put your lips together and try to scream high pitched while vibrating your lips.
you may get a good chirping sound like the crickets.
Default Re: How can I chirp 4th and 5th gear? (Tony Starks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tony Starks &raquo;</TD></TR><TR><TD CLASS="quote">You won't be here long.</TD></TR></TABLE>
why would you say this to me what did i do wrong?
Old May 13, 2003 | 09:46 AM
Ivan's Avatar
senior gold member
I don't think he meant you.
4g4me's Avatar
I dont think he was talking to you
Old May 13, 2003 | 09:49 AM
Default Re: How can I chirp 4th and 5th gear? (4g4me)
oh ok my bad i didnt know i thought i did something wrong. thanx guys
Old May 13, 2003 | 09:52 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy &raquo;</TD></TR><TR><TD CLASS="quote">oh ok my bad i didnt know i thought i did something wrong. thanx guys</TD></TR></TABLE>
No dude, I wasn't talking to you. If I was I would of quoted you like I am now.
Old May 13, 2003 | 09:53 AM
MLogan's Avatar
If it is Electron Blue Pearl you should be able to chirp 4th easily. I would look into some altezzas (genuine APC). They are a good weight reduction
Old May 13, 2003 | 09:59 AM
Default Re: How can I chirp 4th and 5th gear? (MLogan)
Ok ok, after thinking about your topic for quite some time now I came up with your perfect solution.
The problem with you not being able to chirp 4th and 5th is because you obviously have WAY too much weight on the front of your car at those speeds. Here's what you should do.
1) Remove your AC
2) Move your Battery to the rear (make sure it'll fit in-between your 5 15in. subs)
3) Get a carbon fiber hood... they be blingin anyway's... give you mad stunna points
4) Steal a park bench (or buy one from APC) and slap it on your trunk... that **** looks TIGHT anywayz
5) Adjust the wing (bench) so that it puts as much downforce on your rear wheels as possible...
6) Remove front crome 22's and put some steelies on.
Vuola! You be spinnin! with mad crazy stunna bonus points.
Old May 13, 2003 | 10:00 AM
dwn-shift's Avatar
Its all about driving the driving technique . When you shift from 3-4-5 make sure you hear the revlimiter between shifts, if you dont your not trying hard enough. If i were i would just floor it and never take ur foot off the gas, thats how you chirp mad tires Yo...
Old May 13, 2003 | 10:01 AM
Ivan's Avatar
senior gold member
Default Re: How can I chirp 4th and 5th gear? (SlippylesKB)
oh and you gotta make sure your tires are bald too.
Old May 13, 2003 | 10:02 AM
Chris y0!'s Avatar
skrew that.
just put 2 spare tires on your front. spin all th3 way thrU 5th y0
Old May 13, 2003 | 10:03 AM
Default Re: How can I chirp 4th and 5th gear? (Ivan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ivan &raquo;</TD></TR><TR><TD CLASS="quote">oh and you gotta make sure your tires are bald too.</TD></TR></TABLE>
DAMN! That was on my list too!! Must have over-looked it
Old May 13, 2003 | 10:18 AM
keithv's Avatar
its about that time...
aych2h
Oct 26, 2007 11:14 PM
CR3X
13
Oct 25, 2007 01:56 PM
cr0c0
Nov 2, 2005 06:05 AM
ITR198
May 12, 2005 08:59 AM
jond
Apr 28, 2003 11:40 AM
