upgrading brakes on my 09 civic si
i want to upgrade my brakes using teg parts any one know what years i can use for the rear disc and is there any advantage to putting integra front discs and calipers on
how many mods are involved....any that are a direct bolt ons
anyone out there with a similar setup advice and suggestion would help very much
thank you
thank you
Welcome cdn90civicsi. I see you are new here. This topic has been talked about previously, and if you use the search function you will find topics covering this in detail. The search function is your friend.
But to help you out. Yes you can use the Teg rear and front brakes from the 90-93. They are a direct bolt on, but you have to get an alignment done after the install.
Don't use Integra knuckles in the front. Your suspension geometry will not be correct afterwards (camber related). Use 90-91 Civic EX knuckles. Integra trailing arms work fine though.
*HandGrenadeEK*
May 28, 2010 06:46 PM
wunPOINTeight
Jan 15, 2007 02:26 PM
BigGreenAuto
Nov 20, 2006 10:08 PM
