big brakes
Old May 13, 2003 | 04:59 AM
CRX_Si's Avatar
Default big brakes
i want to use some brembo cross drilled/slotted rotors from an integra on the front of my 91 CRX Si. do i need different calipers? i heard it was plug and play with the 10.2". and will they fit under a stock 14" Si wheel? thanks
Old May 13, 2003 | 05:51 AM
madman13lm's Avatar
Default Re: big brakes (CRX_Si)
I doubt then will. I believe in order to go to that size brakes you need 15 inch wheels. Correct me if Im wrong.
Old May 13, 2003 | 07:42 AM
stockcrix1616's Avatar
Default Re: big brakes (madman13lm)
isnt the teg disk 10.8? ive always heard you have to use the spindle and that will hold the caliper and the break disk. it can also throw out alignment and camber. i also believe you have to run 15's.
Old May 13, 2003 | 07:49 AM
Hondasaurs's Avatar
The Integra brakes are bigger. I have GSR brakes on my hatch. You would have to get the Integra hub assembly to put them on your CRX.
I had Del Sol 14 inch alloy wheels on my hatch. There is about 1/8 inch of room, between the caliper and wheel, with the Integra brakes.
Old May 13, 2003 | 03:38 PM
NCchris's Avatar
Default Re: big brakes (B17A Hatch)
The 10.2 Teg rotors are the same as 90-91 EX fronts. You would need the EX knuckles and EX or Teg calipers to work properly.
HTH
chris
Old May 14, 2003 | 01:27 AM
eraser's Avatar
get the complete brake assy off the 90-91 civic EX
the brakes will clear 88-89 SI wheels........but the 90-91 wheels will require a 3mm spacer..or just get bigger wheels
Old May 14, 2003 | 04:48 AM
bryant's Avatar
Default Re: big brakes (NCchris)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NCchris &raquo;</TD></TR><TR><TD CLASS="quote">The 10.2 Teg rotors are the same as 90-91 EX fronts. You would need the EX knuckles and EX or Teg calipers to work properly.
HTH
chris</TD></TR></TABLE>
Why by teg brakes and not the knucles. Get the whole 90-91 EX knucles and bigger brakes or get the whole 90-93 teg knuckles and brakes and slap them on. They both work the same, but you will most likely need to hit up an alighment shop for camber, toe, and caster adjustment with the teg knuckles. But the EX knuckles and brakes are going to much harder to find.
dusterbd13
Jul 8, 2009 01:22 PM
deucedeuceEK
Jan 12, 2006 01:13 PM
Sinner
Dec 19, 2005 08:00 PM
mini-cRx
22
Jan 2, 2002 05:06 PM
