Redoing Harness, now no fuel or brake lights
Ok, I will try to be as specific as I can. We were swaping out the interior harness on an 89 CRX DX with that of an 1991 CRX SI. We have everything working accept for the brake lights and the fuel pump. The engine will turn over with starter spray, but other than that its not getting pressure. We have determined that the injectors are working. I think its something to do with the rear of the interior harness. although, when the lights come on, the rear running lights turn on. If any of you know what could be wrong please help.
Thanks
Adam
Thanks
Adam
Sorry if I sound funny. I have been up since 5, worked a full day, and have been working on my car since I got off. Its now midnight.
i just did the same thing check your ground underthe dash right next to the hood release.if that doesnt work check the back ground by the taillights and last but not least CHECK THE PLUGS TO THE FUSE BOX !!!!!!!!!!!!!i had to swap out the fuse box i have an extra 89 si fuse box let me know ill give it to u for just shipping cost
well, whats going on is we have the front of the car wired entirely with the SI interior harness and engine harness. however, since we are using a DX fuse box we just pluged in the 89 DX rear interior harness. You wouldnt happen to have that piece as well would you? The guy I bought my harness from cut the lines at the end of the rear harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MAD SCIENTIST »</TD></TR><TR><TD CLASS="quote">i just did the same thing check your ground underthe dash right next to the hood release.if that doesnt work check the back ground by the taillights and last but not least CHECK THE PLUGS TO THE FUSE BOX !!!!!!!!!!!!!i had to swap out the fuse box i have an extra 89 si fuse box let me know ill give it to u for just shipping cost</TD></TR></TABLE>
Im praying this will solve it. How did you get your hazards to work? Is it this different because Im going from 89 to 91, or is it this different because its DX to SI or is it both.
I'm dying here, I have to get this car back on the road. I will most certainly take you up on that offer.
yes it is diferent between the model years the 88-89 are above the steering wheel 90-91 are on the gauge cluster cover with the defroster.let me know what u need
McD6288
Oct 15, 2018 08:36 AM
hondata760
12
Jul 15, 2013 08:31 PM
motoman32002
Nov 17, 2011 05:07 AM
