Can I run Y8 injectors on my A6?
Old May 12, 2003 | 06:50 PM
photonjedi808's Avatar
Default Can I run Y8 injectors on my A6?
I have a Z6/A6 mini-me and was thinking of using some Y8 injectors
I did a search and someone said you have to take out the resistor box, Another person said that they ran fine with the box still in, just had to modify the plug slightly to fit
Old May 12, 2003 | 07:03 PM
FourthGenHatch's Avatar
Default Re: Can I run Y8 injectors on my A6? (photonjedi808)
The problem is Y8s would be OBD-II, while your A6 is OBD-0. MPFI 0's had low impedance injectors, and I think the OBD-II were high impeadance, so you will fry those injectors unless you convert to OBD-II. Why not just find more A6 ones.
Old May 12, 2003 | 07:14 PM
zCivic's Avatar
Default Re: Can I run Y8 injectors on my A6? (FourthGenHatch)
Will have to remove the injector resistor box....OBD0 are low ohms while OBDI and OBDII are both high ohms. The resistor box will raise the ohms load so if running high ohm injectors and then the resistor box will fry the ECU. Higher ohms load, harder for current to run and thru vice versa. Also the injector plugs are different so will need some OBDII plugs for the injectors. Or just find another set of OBD0 injectors there all 240cc's or get some 92-95 preludes and there 290cc and there still low ohms
Old May 13, 2003 | 02:21 AM
my friend has some Y8 injectors laying around after a swap. just wanted to know if I could use em.
thanks
Old May 13, 2003 | 04:15 AM
Fred n J_v2.0's Avatar
i got some a6 injectors if you need em
Old May 13, 2003 | 07:26 AM
redzcstandardhatch's Avatar
something different
Default Re: (95VXFRANK)
i heard you could use them if you just tie all the wires at the injector resistor box together. thats pretty much what you do in a obd2 swap for the injectors, it should work fine.
Old May 13, 2003 | 08:53 AM
4drEF's Avatar
Keyboard Humorist
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by photonjedi808 &raquo;</TD></TR><TR><TD CLASS="quote">I have a Z6/A6 mini-me and was thinking of using some Y8 injectors
I did a search and someone said you have to take out the resistor box, Another person said that they ran fine with the box still in, just had to modify the plug slightly to fit</TD></TR></TABLE>
Different plugs and different resistance. Mod or splice in the OBD2 injector connectors. Hack off the injector resistor box plug and solder all the wires together. Go for a drive.
Old May 13, 2003 | 09:16 AM
Timmah!!'s Avatar
Default Re: Can I run Y8 injectors on my A6? (4drEF)
Would this be the same thing to do in order to use the injetors that come with my JDM D15b??
columbushatch
Jan 17, 2009 11:08 AM
DrivinVtec
Sep 17, 2007 10:08 AM
phatrick2332
Nov 21, 2003 01:20 PM
halfpint
Jul 8, 2003 12:17 PM
vtecrx
11
Sep 14, 2002 08:19 AM
