edelbrock GS-R pro-flo headers into an LS = problems?????? (could use advice!)
Old May 12, 2003 | 06:40 PM
jamessh1's Avatar
Default edelbrock GS-R pro-flo headers into an LS = problems?????? (could use advice!)
Okay, I can get a set of unused edelbrock pro-flo 4-2-1 headers off a friend (gs-r owner) for an amazing price (he's going with jdm 4-1 instead), I went to the edelbrock site, and sure enough there are different part #'s for ls, gs-r, itr. Would I have to get a shop to install the piece (is the cat going to have to be moved, will i need an O2 sensor welded on, etc.). I've never bought an edelbrock piece, and at the moment, I'm debating between DC 4-2-1 and the pro-flo's. Any advice would be great!
Old May 12, 2003 | 07:05 PM
jamessh1's Avatar
Default Re: edelbrock GS-R pro-flo headers into an LS = problems?????? (jamessh1)
Can someone comment on the quality of the edelbrock pro-flo header in general? would it be a better choice than the DC 4-2-1???
Old May 14, 2003 | 07:11 AM
Marauder's Avatar
The Edelbrock header is a nice piece! I saw someone dyno test the Edelbrock GSR header and it made 9 whp on a stock engine. I think they only ran it against the DC 4-1 header, which only made about 4-5 whp. I personally feel the Edelbrock 4-2-1 header doesn't get much press.
As far as fitting it in your car.....I don't know. I don't know whats different between an LS and GSR.
Old May 14, 2003 | 08:39 AM
The-LS's Avatar
Default Re: edelbrock GS-R pro-flo headers into an LS = problems?????? (Marauder)
as far as I know, it should bolt up fine to the motor and bracket. Your problem will possibly be in length (this all depends on what gsr year your buddy's header was for). I think at worse you'll have to change the length (cut about 6"??) on your b-pipe (the pipe from the cat to the muffler).
I'm speaking from experience and research of doing a ITR to 95 gsr header swap. Maybe someone who did the exact same thing you are asking for can give you some more info. As I recall from my head, 00-01 gsr header should bolt right up?
Old May 14, 2003 | 08:45 AM
Spoodge's Avatar
From: Slut City aka San Diego, Ca, United State Of King
not a fan of dc header's... the ceramic ones tend to crack.....plus you dont produce as much power.. let use kno what you do...
Old May 14, 2003 | 08:47 AM
JCushing's Avatar
the problem like stated earilier will be the length... the gsr uses a longer cat from 94-99 i belive then 00+ uses the same length. the headers on itr and ls engines are longer than the gsr ones so you should be good with installing a gsr cat...
eg64u
Aug 1, 2004 02:44 PM
LSpimpTEC
Jun 19, 2004 12:45 AM
SpoonboyChoi
Mar 16, 2003 05:02 PM
mickey513
Jun 19, 2002 05:50 PM
speeddave
Apr 3, 2002 08:31 AM
