BI-xenon wiring...Help a brainless retard out!!!
Old May 12, 2003 | 04:14 PM
ill_take_one's Avatar
Default BI-xenon wiring...Help a brainless retard out!!!
Guys, i'm so confused.
I've got a set of denji projectors, with Hella bi-xenon projectors retrod in. I have NO clue how to wire my hid's up to the new harness i got with the headlamps. heres some picts.
Please help me out if possible!
thanks
also, heres how i was told to hook the HEADLAMPS harness up to my car. is this correct?
1 - The harness should have one male headlight plug that plugs into the passenger side oem headlight plug.
2 - The harness has two female headlight plugs that plug into the projector headlights.
3 - Each female headlight plug has a black ground wire on it that must be grounded under a bolt or screw that contacts the metal of the car body.
4 - There are two red ground looking wires that extend from the fuses on the harness. They both should be bolted to the (+) terminal on the battery.
5 - The drivers side oem female plug is unused with this installation.
Once done this way, the low beam should make just the outer projector beam illuminate and the high beam will make the hight and low beam illuminate at the same time.
Old May 13, 2003 | 06:25 AM
Default Re: BI-xenon wiring...Help a brainless retard out!!! (ill_take_one)
C'mon you guys, i know someone out there knows how to help me out?!!
Old May 13, 2003 | 07:37 AM
IntEGNYC's Avatar
im guessing it didnt come with instructions.
You might want to help yourself out by diagraming the wiring on the lamps and the light wiring. it would be easier for people here to help figure out what to connect to what wire then...
good luck
Old May 13, 2003 | 08:16 AM
Default Re: BI-xenon wiring...Help a brainless retard out!!! (IntEGNYC)
Well I've got my headlight harness hooked up, except for that little connector that is shown in pict three. I have no clue what that is.
My main questions are:
1) how do i keep my highand low beams on at the same time
2) how do i wire the HID bi-xenon projectors to this wiring harness?
And you're right, no instructions are given. THis is a retrofit.
I have no clue how to make a diagram for my harness or whatever? Shouldn't those instructions i posted help a little (in the first post)??
thanks guys for any help you can give me...I'd really love for these to be working soon...
Old May 13, 2003 | 08:36 AM
skribblah's Avatar
get someone to do it for you before you hurt yourself, or ...
Old May 13, 2003 | 09:05 AM
Default Re: (skribblah)
lol...i've tried...but i've failed.
thugmau
Dec 26, 2009 07:39 AM
1Quikgsr
Jan 18, 2006 08:26 AM
ZEAL-SPORTS
Nov 30, 2004 09:42 AM
Nuts
Jun 6, 2003 04:51 PM
ill_take_one
35
May 18, 2003 07:24 AM
