what kind of axles for bseries?
Old May 12, 2003 | 08:01 AM
crashtest Sonny's Avatar
Default what kind of axles for bseries?
when i had my b16a.. my driver side axle keeps breaking (the joints keeps popping open and all that bearing falls out). it has happen to be 3 times already. what would the problem be? i had place racing mounts.
Old May 12, 2003 | 09:57 AM
slowpokesi's Avatar
Default Re: what kind of axles for bseries? (4g_civic_si)
maybe you dont have your mounts in good, i had to use washers on my driver side mount,
also are these new axles?
you have to be reallly carefull when putting them in,
btw i used 91 integra axles.
Old May 12, 2003 | 10:49 AM
nuc79's Avatar
<FONT COLOR="blue">http://www.hasport.com/News/Articles/Hasport%20Axles.htm</FONT>
If you are using a 90-93 teg intermediate shaft and axles, you should have no problem. The axles that you should use depend on the intermediate shaft you're using.
Old May 12, 2003 | 11:37 AM
Default Re: what kind of axles for bseries? (nuc79)
i was using the 1st gen b16a intermediate shaft.
Old May 12, 2003 | 12:00 PM
slowpokesi's Avatar
what axles have you been using?
im using 91 integra axles. and a jdm b16 intermediat shaft
Old May 12, 2003 | 12:05 PM
FOrSfEd's Avatar
Default Re: what kind of axles for bseries? (slowpokesi)
The passenger side dosen't effect the driver side so, you could have an SIR intermediate shaft and still use a 90-93 axel on the passenger side.
Old May 12, 2003 | 12:24 PM
nuc79's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">i was using the 1st gen b16a intermediate shaft.</TD></TR></TABLE>
But is it from a Civic SiR(EF) or an Integra XSi(DA)? Both are JDM 1st gen B16 cars. Your best bet is to see if you have the bottom, or middle intermediate shaft in this pic:
Your problem sounds like you are using a drivers' axle that is too short for the intermediate shaft(hence the shaft popping out of the joint). Like maybe a 86-89 teg axle instead of a longer 90-93 one.
Best bet to fix everything: 90-93 intermediate shaft + 90-93 left axle = no more problems.
Old May 12, 2003 | 12:35 PM
wickedEFguy's Avatar
it also depends on what tranny you have... If it's the S1, A1, or J1 you can use 90-93 Integra Axels and just remove your dust shield from your hud. But if it's a Y1 tranny then go to http://www.driveshaftshop.com to get some custom ones made for that tranny
Old May 12, 2003 | 01:05 PM
Default Re: what kind of axles for bseries? (Ninja_Jc7)
my intermediate shaft is from integ xsi. and i have j1 tranny.
tmihok
Aug 7, 2004 03:34 PM
b18crx
May 26, 2003 06:28 PM
garagespecial
May 19, 2003 11:29 AM
si foo
May 12, 2002 02:14 PM
juicy.koreans.suck
10
Jan 10, 2002 10:47 AM
