Rust On body
Old May 11, 2003 | 08:07 PM
TurBoXBirD16's Avatar
Default Rust On body
What's the best way to stop rust from spreading out?? and removing it??
it's a very small part of the rear bumper... thank you
Old May 11, 2003 | 08:57 PM
crxforum's Avatar
Default Re: Rust On body (TurBoXBirD16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurBoXBirD16 &raquo;</TD></TR><TR><TD CLASS="quote">What's the best way to stop rust from spreading out?? and removing it??
Stop rust by cutting it out. Stop rust from coming back, get your car treated at a place like Ziebert or Krown and they can treat your car. And make sure that you do it every year. You can always sand or cut it all out and fill it in with Bondo but usually that is only a fix for a little while. Cutting out the whole rust and then some and using another piece of metal and weld that in place and sanding it smooth and painting it is the way to go to make sure that it wont come back again. I hope that this helps you out.
CRX Forum
Old May 11, 2003 | 09:06 PM
Default Re: Rust On body (crxforum)
holy.. cutting it out!!??
any other easier way to do it??
Old May 12, 2003 | 05:21 PM
performula's Avatar
Usually when rust starts it will come back over time. Not from the actual spot, but from the welds when they (bodyshop) weld the new piece in. The welds from the opposite side of the fix will corrode over time and penetrate through your fixed section.
Guess that's life, but it is worth it if you love your car.
ef hatchDUDE
Paint and Body
Sep 22, 2012 12:23 PM
EFstyle
Oct 19, 2008 05:25 PM
speed_racer012
Jan 25, 2004 01:54 PM
AgentJam
Oct 28, 2003 04:25 PM
Zuerst
Jun 25, 2003 03:27 PM
