H22 Direct port installation, where did you do it?
Hey guys, Im in the process of installing my NX direct port (conversion from the single fogger). I remover the intake manifold, but there seems to be VERY LITTLE room to tap the manifold. There is no room on the top, and on the bottom you can see 3 plenums easily, but its hard to see the 4th (towards the drivers side). This is on a 98 jdm h22a in a 96 accord. The most likely place seems to be on the bottom, as big a bitch as it may be to change the jets later.
Also, on the bottom of the manifold, what is that black box attached to it? I broke off one of the plastic things connected to a hose. Is it expensive to replace? Can it be moved or removed?
Thanks
Thanks
