H22 Direct port installation, where did you do it?
Old May 11, 2003 | 07:54 PM
dvp95's Avatar
Default H22 Direct port installation, where did you do it?
Hey guys, Im in the process of installing my NX direct port (conversion from the single fogger). I remover the intake manifold, but there seems to be VERY LITTLE room to tap the manifold. There is no room on the top, and on the bottom you can see 3 plenums easily, but its hard to see the 4th (towards the drivers side). This is on a 98 jdm h22a in a 96 accord. The most likely place seems to be on the bottom, as big a bitch as it may be to change the jets later.
Also, on the bottom of the manifold, what is that black box attached to it? I broke off one of the plastic things connected to a hose. Is it expensive to replace? Can it be moved or removed?
Thanks
Old May 11, 2003 | 09:57 PM
Teen Heartthrob's Avatar
Default Re: H22 Direct port installation, where did you do it? (dvp95)
how much was the conversion kit? (if you dont mind me asking)
Old May 12, 2003 | 03:38 AM
laughinxxx's Avatar
New User
Default Re: H22 Direct port installation, where did you do it? (Teen Heartthrob)
Have fun.
Annular nozzles into the back of the manifold facing the firewall would be easiest.
Old May 12, 2003 | 05:45 AM
DubbleD's Avatar
Default Re: H22 Direct port installation, where did you do it? (laughinxxx)
cant help ya with the nx system.....but i kno what that box is....its a vaccum tank - tank vaccum...whatever (i call it the **** box). i broke some of those tips too....i jus jb welded them bitches back together making sure it wasnt blocking the passageway...its strong as hail
Brownjd
Mar 1, 2011 07:33 PM
adam8103
Jan 20, 2006 08:25 AM
SAVIOVEGA
Feb 18, 2004 09:52 PM
H22assbusa
May 16, 2003 11:17 AM
