HUGE problem
Old May 11, 2003 | 07:33 PM
Spudddy's Avatar
Default HUGE problem
Alright so i was dumb when i was wiring my smc500 and wired it on the FIRST plug.. plug A.. which was p32 (this is on a odb2 car with a p2t ecu) so in my ventures to start the car over and over again the dome light just went dim and the battery slowly started to die. So now anyway since I realized the mistake fixed the wiring the battery is still dying. (running a vafc now) So to figure out whats going on i find that the fuse "Alternator SP Sensor" 7.5 fuese blew.. so i replaced it droveit and well it blew again. The car's alternator does run, with a new fuse in it if i pull the postive lead off the battery the car dies. It just wont recharge/run the car I am sooooo screwed and sooo stuck. Should i get the alternator tested to see if it works?
Old May 11, 2003 | 07:38 PM
Spudddy's Avatar
side note, my speedometer doesnt' work either, oh yeah also in my turbo build the injector to the second cylender from the ender.. driver said.. had a fuel leak in it.. fuel leak into the alternator blowing it?
Old May 11, 2003 | 10:32 PM
bhive9024's Avatar
Default Re: (Spudddy)
although i cannot answer your question, a thread title that is more descriptive of the thread would attract more attention to your thread and will give you a qicker response in the future to your problems
deathdillan
Apr 28, 2014 02:03 PM
willpower102
Jul 28, 2013 05:12 PM
logeywartooth
Sep 14, 2008 07:10 PM
shadowdawn
Aug 9, 2003 06:23 PM
EG6[B16A1]
Jun 28, 2003 09:03 AM
