are civic hb/crx upper a arm the same, or different?
Old May 11, 2003 | 03:10 PM
smokey2.0's Avatar
Default are civic hb/crx upper a arm the same, or different?
i needed a replacement bal joint quick(passenger side upper a arm), so i ran to the junkyard and picked one up from a civic hb. my tires are getting work quicker than they should, specially my passenger side one. and my car has a funny shake at high speeds(70+ mph) the driver side. i'm wondering if that a arm from the hb, had anything to do with these problem i'm having!
Old May 11, 2003 | 03:37 PM
FourthGenHatch's Avatar
Default Re: are civic hb/crx upper a arm the same, or different? (smokey2.0)
Should be exactly the same.
Old May 11, 2003 | 04:28 PM
smokey2.0's Avatar
Default Re: are civic hb/crx upper a arm the same, or different? (FourthGenHatch)
thankx!
Old May 11, 2003 | 05:10 PM
litlekikr's Avatar
make sure the arm's not bent and find a place that does free alignments checks and see what u can figure out from the specs.
Old May 11, 2003 | 05:19 PM
smokey2.0's Avatar
Default Re: are civic hb/crx upper a arm the same, or different? (litlekikr)
i'll see if i find a place that would do a free alignment check up!
packrat79
Jun 30, 2018 05:44 AM
Progress Technology
23
Aug 12, 2009 08:16 AM
lrcrx90
Jan 5, 2007 02:02 PM
b16crex
May 31, 2005 10:41 PM
