Anyone have one piece projector headlights? They have to make em>>
Old May 11, 2003 | 11:22 AM
TheHatchHog's Avatar
Default Anyone have one piece projector headlights? They have to make em>>
I used to have a 95 civic EX. I had one piece projector headlights on it. I waqs wondering if anyone had these or know where I could get em?
Old May 11, 2003 | 11:26 AM
mbsi's Avatar
Default Re: Anyone have one piece projector headlights? They have to make em>> (civicciviccivic)
im guessing this is for a 4th gen, they make them for crx's but I heard they require a bit of customization in order to fit them in our cars.
Old May 11, 2003 | 12:32 PM
GroundZer0 336's Avatar
Default Re: Anyone have one piece projector headlights? They have to make em>> (mbsi)
they make them for crx's ? o mann i need those where could i find them....ive been looking everywhere for them.
Old May 11, 2003 | 01:42 PM
litlekikr's Avatar
as far as swapping them into a civic, there's an article somehwere that tells you how to make them fit. I think it's at http://www.4thgenerationcivic.com . From what i remember, all you have to is swap the brackets over to the new lights.
Old May 11, 2003 | 04:48 PM
uneek4dr's Avatar
Default Re: Anyone have one piece projector headlights? They have to make em>> (litlekikr)
well actually there are no one piece crx projector headlights those are one piece SEDAN headlights and they are not projectors either, in any case to put them in a crx you have to modify the brackets or swap them and also the fenders are different where the corner lenses fit. there was a big disucssion about it on here before its like this
___
___\ civic corner lense
____
___/ crx corner lense
see how the edges curve at different angles? thats where the fender modification comes in
Old May 11, 2003 | 05:07 PM
litlekikr's Avatar
88-‘89 CRX Projector headlight installation into ‘90-‘91 hatchback:
CRX headlights will fit in a hatchback, but require some slight modifications… You have 2 options:
1.) You can swap the mounting brackets from the OEM headlights to the projector headlights.
2.) You can use the projector’s mounting brackets and modify the corner lenses to fit.
** Personally, I would recommend swapping the mounting brackets… I didn’t do that, I used the projector brackets and modified the corner lenses, but in hindsight, it would’ve saved me a lot of trouble if I’d just swapped the brackets. **
For swapping the mounting brackets, you should be able to remove all screws/bolts from each set of lights, and swap everything over. Then, when you install the lights, all the bolts should line up, and the corner lenses should fit without modification.
TOOLS/MATERIALS REQUIRED:
= Assorted screw drivers
= Assorted sockets/wrenches/pliers
• Remove front bumper.
- Remove the 2 screws (Phillips) in each front fender well.
- Remove bumper lenses (2 screws each)
- Remove the 2 bolts under the bumper lip.
- Remove the 4 bolts (2 on each side) that are behind the bumper lenses.
• Remove trim piece from below headlights/hood (1 bolt in center, 1 bolt (each side) under headlights, 1 bolt (each side) in corner lens holes.
• Remove OEM headlights (4 bolts each, 2 on top, 1 on side, 1 on bottom)
• Swap the OEM brackets for the Projector brackets.
• Install projectors, all bolts should line up.
• Re-install bumper trim and bumper (reverse of removal).
• Re-install corner lenses.
For using the projectors mounting brackets:
= Dremel tool with cutting disc
= Drill
= Long 1/8” metal drill-bit
• Remove corner lenses (one retaining screw in headlight bracket)
- Remove the 2 screws in each front fender well.
• Install projectors, all bolts should line up properly.
• Test fit the corner lenses. You’ll notice that the corner lens mounting bracket needs to be modified to fit into the projector mounting bracket. Use a dremel tool with a cutting disk to modify the corner lens mounting arm.
• Once the mounting arm fits, you will need to drill a hole in the headlight mounting brackets to accommodate the corner lens retaining screw. Use an extra long 1/8” drill bit and just drill through the hole in the corner lens mounting arm.
• Add a 1/8” metal screw to hold the corner lenses in place…
Remember to have your projectors professionally aimed/aligned.
Old May 11, 2003 | 05:08 PM
litlekikr's Avatar
that's from the how-to section of the website i said in the previous post.
Old May 11, 2003 | 11:38 PM
89dxhunchback's Avatar
Default Re: (litlekikr)
I'm going to try and mold a CRX front end and 92'-95' projector beam lights into my 89' hizacth back.
Bondo/figerglass = easy but time consuming..
lived dreams
Jun 16, 2009 07:10 PM
09fa5
Honda Civic (2006 - 2015)
Dec 22, 2008 11:32 PM
SirCRX
Aug 30, 2004 07:54 PM
Jester88Si
Feb 17, 2004 06:25 AM
OldSchoolHatch
Jul 8, 2002 04:31 AM
