My car dies when I remove the negitive battery cable...what is wrong?
Old May 11, 2003 | 11:21 AM
jisu009's Avatar
Default My car dies when I remove the negitive battery cable...what is wrong?
What could that be?
1990 HB with B16
Old May 11, 2003 | 11:27 AM
DiPPeD iN miLk Ej CoUpE's Avatar
Default Re: My car dies when I remove the negitive battery cable...what is wrong? (jisu009)
alternator problem maybe
Old May 11, 2003 | 11:54 AM
90da's Avatar
Alternator is on its way out. With the cable removed it should still run, the battery is for starting only.
Old May 11, 2003 | 02:48 PM
jdblack1's Avatar
Default Re: My car dies when I remove the negitive battery cable...what is wrong? (90ef)
Because you lose the chassis ground. The car is only going to run if you remove the positive cable and alternator is good.
Old May 11, 2003 | 02:58 PM
redzcstandardhatch's Avatar
something different
Default Re: My car dies when I remove the negitive battery cable...what is wrong? (jdblack1)
that sounds like its not a problem to me......the car still needs a ground, but i dont know if it runs through the battery for that.....i cant remember how it goes....i'll just shut up.
Old May 11, 2003 | 03:01 PM
jisu009's Avatar
Default Re: My car dies when I remove the negitive battery cable...what is wrong? (redzcstandardhatch)
no it should run with the battery totally disconnected...both positive and negitive...i just isn't
Old May 11, 2003 | 03:07 PM
jdblack1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redzcstandardhatch &raquo;</TD></TR><TR><TD CLASS="quote">that sounds like its not a problem to me..</TD></TR></TABLE>
exactly Why are you disconnecting the negative to test something. The electrical system needs something that is more negative then just the chassis. IE batteries' negative post.
Old May 11, 2003 | 03:11 PM
jisu009's Avatar
https://honda-tech.com/zerothread?id=502177
this thread will give you a little more insight to the problem...Let me know what you guys think...
Old May 11, 2003 | 06:15 PM
89civicdx's Avatar
are we talking about the battery ground?
the car should run without the battery in there so its most likely your alternator.
Old May 11, 2003 | 09:01 PM
RCautoworks's Avatar
Default Re: My car dies when I remove the negitive battery cable...what is wrong? (89civicdx)
Your never suppose to disconnect the battery when the car is running, you could cause an electrical spike and fry something.
civicron
Honda Civic (2001 - 2005)
Aug 5, 2016 05:56 AM
97_hatch
May 21, 2008 02:38 PM
BigIslandBoi
Aug 22, 2006 09:50 PM
dude wheres my car
Audio / Security / Video
Jul 16, 2004 07:16 AM
BK101
Jan 16, 2002 12:56 AM
