I got my code for the Check Engine Light.... need help
Old May 11, 2003 | 08:46 AM
DK4200's Avatar
Default I got my code for the Check Engine Light.... need help
I ran the code 54 today for the crankshaft fluctuation sensor (CKF). I have a 98 Integra w/ B18B motor. Is it ok to run it like this until i can get it fixed or no? When i do check it out and it then needs to be replaced how much would it be? Hopefully that won't be the case but my luck it will. Let me know
Also will this hurt engine performance????
Old May 11, 2003 | 02:15 PM
DK4200's Avatar
Default Re: I got my code for the Check Engine Light.... need help (DK4200)
ttt
Old May 11, 2003 | 02:52 PM
Katman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DK4200 &raquo;</TD></TR><TR><TD CLASS="quote">I ran the code 54 today for the crankshaft fluctuation sensor (CKF). I have a 98 Integra w/ B18B motor. Is it ok to run it like this until i can get it fixed or no? When i do check it out and it then needs to be replaced how much would it be? Hopefully that won't be the case but my luck it will. Let me know
Also will this hurt engine performance????</TD></TR></TABLE>
hmm, that's odd.
Your car is a 98 Integra which IS obd2 equipped and you should, by default, have the CKF sensor on your stock engine. I have a feeling you're leaving out some info.
- have you peformed an engine swap or some kind of block change lately? and if so, what year is the motor you put into your 98 teg ?
if not, and you have your original engine, have you checked the CKF sensor to see if it somehow came loose or unplugged?
btw, this sensor is located on your oil pump as seen on this OBD2 sohc engine:
Old May 11, 2003 | 06:07 PM
DK4200's Avatar
Default Re: I got my code for the Check Engine Light.... need help (Katman)
Thanks Katman for the picture... i have not done a motor or head swap of any kind. It is all original with the car. I have not check it out yet to see if it came unplugged. I have the Unorthodox Racing Underdrive Pullies... i doubt it but do you think they made any difference? Im gonna look everything over on monday or tuesday so ill let everyone know how i made out
Old May 11, 2003 | 07:50 PM
Katman's Avatar
hmm yeah take a looksy, maybe the UO pulley rubbed against the CKF wires and cut through on accident..
Old May 11, 2003 | 09:19 PM
wm5holla's Avatar
[QUOTE=DK4200] I ran the code 54 today for the crankshaft fluctuation sensor (CKF). how do u run codes?
Old May 12, 2003 | 07:30 AM
DK4200's Avatar
Default Re: I got my code for the Check Engine Light.... need help (wm5holla)
go to this webpage and that is how you do it... very easy, takes about 5 minutes
http://www.c-speedracing.com/faq/06.php
Old May 13, 2003 | 12:23 PM
wm5holla's Avatar
i cant find it....On the passenger side of your car, under the dash beneath the glove box, you will find a green cover above the kickpanel that houses a blue connector that has two wires. can someone post a pic of it!!http://www.c-speedracing.com/faq/06.php
Old May 13, 2003 | 12:49 PM
DK4200's Avatar
look above i already got the link posted
palmtree
Jan 28, 2013 12:06 PM
boostedteg4dr
Jan 6, 2008 11:31 PM
samuel_gatech
Aug 26, 2006 01:56 PM
DK4200
May 10, 2003 07:49 PM
syxxpac623
Feb 27, 2002 03:39 PM
