JDM ITR 5 lug suspension swap
Old May 11, 2003 | 08:02 AM
R.S.'s Avatar
Default JDM ITR 5 lug suspension swap
What are the benefits of an ITR 5 lug conversion? I know it's stronger then 4 lug and a wider wheel selection but what else, like performance wise. The suspension is the most important thing to me on my car and i would like to eventually take this car to some auto cross type tracks and race around and go to those schools for learning how to race on those types of tracks.
I found a thread on this @ JDMC, but i want to know da benefits of doing it on a teg.
http://www.jdmcivic.com/forums...16198
here are da descriptions and prices from http://www.passwordjdm.com/passJDM2.htm
JDM ITR 98spec 5 lug 5x114.3 32mm suspension swap w/wheels & tires $1649.00 plus shipping -incl:frnt knuckle assemblies w/brake components, rear trailing arms w/brake components , a set of 16" JDM ITR CW wheels/tires. not incl: brake lines, lug nuts, axles, lower control arms(LCA), sway bars, or installation instructions.
JDM ITR 98spec 5 lug 5x114.3 32mm suspension swap $999.00 plus shipping -incl:frnt knuckle assemblies w/brake components, rear trailing arms w/brake components, not incl: wheels/tires, brake lines, lug nuts, axles, lower control arms(LCA), sway bars, or installation instructions. -will fit EG or DC stock axles.
Old May 11, 2003 | 09:28 AM
Rory Breaker's Avatar
Default Re: JDM ITR 5 lug suspension swap (JDM R)
Well, youll have a better braking system for one. You'll also be able to run a full ITR suspension (springs/shocks) with the conversion, as youll have R LCA's. You'll also be able to run some of the higher end JDM coilovers that are designed specifically for ITR's.
Old May 11, 2003 | 10:18 AM
surge2k's Avatar
Default Re: JDM ITR 5 lug suspension swap (newgsrdriver)
nice
Old May 11, 2003 | 01:04 PM
R.S.'s Avatar
so do u think it will be better to get these:
JDM ITR 98spec 5 lug 5x114.3 32mm suspension swap w/wheels & tires $1649.00 plus shipping knuckle assemblies w/brake components, rear trailing arms w/brake components, a set of 16" JDM ITR CW wheels/tires.
JDM ITR LCA $79.00/pair plus shipping
JDM ITR shocks/springs $99.00/set plus shipping
JDM ITR sway bars fronts or rears $79.00/ea plus shipping
Stainless Steel Brake Lines
instead of spending the same amount of $$ on less after market products and still have 4 lug
Old May 11, 2003 | 01:14 PM
In terms of money, you can still have a comprable setup of aftermarket parts for way less than $2k there.
Check out http://www.fastbrakes.com for the brakes. For the $2k, you could score bigger brakes, springs, adjustable shocks, Rotas/tires, swaybars, and SS lines. At least.
This is all depending on what you want to do with the car, and if you really are pushing the limits of the stock or modified stock componens. You may be happy with just some blanks, upgraded Hawk or Cobalt pads and some SS lines. The ITR conversion is definitely nice, but its pricey. Essentially, you pay $1600 for better brakes, 5 lugs, and wheels/tires. When it comes down to it, you can spend $500 at fastbrakes and $700 on Rotas/Tires if you wanted.
Ek9_Cuhzz
Northwest (Sales)
Jul 27, 2010 09:08 PM
AntonioH
Mar 10, 2005 08:47 AM
inzaneN1
Feb 8, 2004 10:36 AM
Sassafrass
Oct 8, 2003 09:00 PM
